Beovox 5000
Orava
Finland
Posts 991
Orava Posted: Tue, Nov 27 2012 8:57 AM
Hi
Is there any known issues with these speakers?
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Tue, Nov 27 2012 9:26 AM
Which type?
/  Johan
Orava
Finland
Posts 991
Orava replied on Tue, Nov 27 2012 9:39 AM
Johan:
Which type?
/  Johan
Ah, there is also panel, I forgot....
These
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Nov 27 2012 10:28 AM
There are three types of the big 5000 speaker. The one you picture is the mark 1 and is good but needs the cubes as the tweeters, being cones, are very directional and will have quite a small sweet spot. The mark 2 tries to get round this by having two angled cone tweeters - you don't see that many of these - the picture on site is a pair I thought of buying but they are not as nicely made as the mark 1s - and you have the mark 3s. The last have the advantage of dome tweeters so have much better treble spread - Frede thinks these are the best - they can still be used with cubes though the benefit is probably more aesthetic as well as giving you the chance to spread the sound stage - mine sound a bit dull so probably need new capacitors etc. The midrange unit is oval which makes repair a bit more interesting!
Peter
Orava
Finland
Posts 991
Orava replied on Tue, Nov 27 2012 11:32 AM
Peter:
...The midrange unit is oval which makes repair a bit more interesting!
Could there be a promlem with these mid's? I dont know yet witch type they are... They were offered to me as Beovox 5000...
Bass elements, rubber, paper...?
Orava
Finland
Posts 991
Orava replied on Fri, Nov 30 2012 1:22 PM
Yes, they are Mk2 offered.
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Nov 30 2012 3:44 PM
The oval drivers on my Mk3s needed repairing and needed new surrounds. Oval ones are tricky to find but Recone adapted some specially. Have a look and listen if you can - they could be fine.
Peter
Page 1 of 1 (7 items) | RSS
