connect iphone to beomaster 5500 using beolink 1000
jacqueselie
Posts 1
jacqueselie Posted: Sun, Mar 10 2019 10:07 AM
Dear friends, i have a beomaster 5500 with cx100 speakers and a blink 1000. I bought this morning a jack to connect the iphone to the beomaster via the earphone output located on the front of the beomaster in mind to play the iphone music from the beomaster.  I thought it may work if i could switch the beomaster to aux mode but i cannot find it using the beolink. Any help would be well appreciated. Thanks a lot.
DMacri
United States
Posts 881
DMacri replied on Sun, Mar 10 2019 11:42 AM
I might be a little confused, but I think you mean you have the iPhone headphone output connected by a cable to one of the BM5500 inputs- not the front headphone output. If you did, you would have two outputs connected together, and that just can’t work. Instead, you can get a nice iPhone to din connector cable from Steve at SoundsHeavenly to tie into one of your available line level inputs if you Beomaster. You just can’t use the phono input because that uses an internal RIAA amplifier to boost and equalize the cartridge output.
My BM is quite full, so I use the Tape2 input. You can select that input using a Beolink 1000 through “Shift” and then “A.Tape”. Make sure you have your iPhone volume level turned way up when connected to the Beomaster, and turned down to normal level when disconnected.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Millemissen
Flensborg, Denmark
Posts 14,680
A cable like this
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi jacqueselie,
Welcome to Beoworld!  Yes, the headphone socket is an output from the Beomaster, you need an input socket like the Tape socket on the rear panel to feed sound from the phone into the B&O system.  This cable will allow you to connect an iPod or phone to the Tape socket on the back of your B&O system:-
https://soundsheavenly.com/bang-olufsen/minijack-to-aux-in-ipod-to-beosound-beomaster-beocenter-using-aux-din-socket
Please set the phone volume to maximum when connecting to the B&O system – this is normal when using a portable music player with a home audio system due to the low output levels produced by the phone.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (4 items) | RSS
