BeoSound 9000 Floorstand
This post has 9 Replies | 1 Follower
MisterDarlin
Posts 24
MisterDarlin Posted: Sun, Mar 17 2019 3:45 AM
I’ve noticed two different models of floorstands for the BeoSound 9000. Model 2055 and model 2065. Are there any differences between the two?
PaulGiles
Posts 218
PaulGiles replied on Sun, Mar 17 2019 7:18 AM
I think the earlier one was a more polished finish whereas the later one was more of a brush effect. (Base)
Unsure on model numbers though.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, Mar 17 2019 9:44 AM
There were indeed two 'styles' - but I was actually unaware they had different type numbers!
The first version had a polished aluminium 'trim plate' on the circular base. I'd guess these ran for maybe 2-3 years from the launch of the 9000 in 1996 to around 1998/9. The second version had the aluminium trim plate in brushed aluminium (circular effect) to match the casing of the unit. The circular base of the stand on the later version was actually very slightly larger.
If you find an earlier polished version cheap enough there's nothing stopping you popping off the trim and replacing it with a later one. It's only held down with double sided tape but you may have to get a bit rough with it!
Lee
Beosince98
Posts 274
Beosince98 replied on Sun, Mar 17 2019 11:12 AM
The later stand is hight adjustable, too. Either to have it match Beolab 8000 or Beolab 1.
MisterDarlin
Posts 24
I believe 2055 is the earlier model and 2065 is the later model. Can someone confirm this?
MisterDarlin
Posts 24
Beosince98:
This is great info! Lost out on an auction for a brand new 2055 recently and was kicking myself. Definitely prefer the 2065 since I plan on getting some 8000’s to match. Thanks!
MisterDarlin
Posts 24
PaulGiles:
I believe 2055 is the earlier model and 2065 is the later model. The service manual indicates that the 2065 is height adjustable. Can someone please confirm this?
MisterDarlin
Posts 24
9 LEE:
Lee
That’s good to know, thanks!
Rob - Danish AV
Melbourne
Posts 376
i thought it was to suit Beolab 6000/8000 height adjustments?
MisterDarlin
Posts 24
I'm looking at the diagram from the service manual and I don't understand how there are two height adjustments. I just see 1 height...
Page 1 of 1 (10 items) | RSS
