Powerlink Kabel 7 oder 8 polige Dinkabel?
Stereomensch
Posts 322
Stereomensch Posted: Sat, Mar 23 2019 3:01 PM
Hallo b&o Freunde,
ich habe ja ein 7000 Beosystem und Beolab Penta mk3 Lautsprecher.
Reichen 7 polige Dinkabel oder muss ich 8 polige Dinkabel verwenden?
konkret fehlt der mittlere Pol.
gruss und Dank
Christian
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hallo Christian,
Sorry for replying in English.  The middle pin of the cable (pin 8) is not needed, but all other 7 pins must be connected in the cable for the speakers to work correctly with the display working.  You need a fully wired Powerlink mk.2 cable to get the speakers working correctly:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/23-2551-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
