Use Beolab 3500 with BeoCenter 6-26
This post has 1 Reply | 2 Followers
fsiprou
Posts 7
fsiprou Posted: Sun, Mar 24 2019 2:46 PM
Hello,
I'm trying to use my Beolab 3500 as an additional speaker for my BeoCenter 6-26.
Do you know if it's possible?
I currently use the BeoCenter with my computer (image and sound).
Eventhough I plugged a masterlink between the two systems, it doesn't seem to work .
Would you have any advice?
Thanks in advance :)
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hello fsiprou,
Welcome to Beoworld!
Whilst you could potentially use a Beolab 3500 with the TV via Masterlink, this won't work well as this speaker is intended for use in a separate room away from other B&O products (ie. as a link room speaker).
You will get far better results by adding a pair of stereo Beolab speakers instead (ie. Beolab 4000, 6000, 8000, etc) as these will give great sound without requiring separate remote control commands for the speakers.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
