Beoplay M5 - local control sometimes unresponsive ?
Dyssegaard
Copenhagen, Denmark
Posts 263
Dyssegaard Posted: Mon, Mar 25 2019 2:56 PM
The local control on my M5 is sometimes problematic. Volume control (left/right turns) is always ok, but tapping in order to start/stop/change source is often unresponsive.
After power off/on everything is ok again as long as I only use the local control. However, when start to use the B&O app, the problem very often comes back.
Has anybody else had the same problem?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
ngnear
Posts 245
ngnear replied on Tue, Mar 26 2019 12:59 PM
I have also noticed this. I thought at first something was broken, but then it worked again.
Doesn‘t really make much difference to me as I don’t usually operate it manually.
Tim
Dyssegaard
Copenhagen, Denmark
Posts 263
ngnear:
Tim
Thanks for your feedback. Good to know.
I will try to use local control and/or my Beoremote One BT with the M5 instead of the B&O app for a couple of days, to see if it’s the app that is causing the problem.
Page 1 of 1 (3 items) | RSS
