What are they used for especially the 1612 and the 1638? I would love to get music from my computer to my Masterlink setup. What one would be best??
i have a Beosound Overature Beolab 3500 Beolab 2000. And a few passive units. As well as a Beosound 2300 that is not in the system.
Thanks guys. Just looking for some thoughts!!!
Hi there,
plots of older posts on this topic so have a browse but a short summary here:
According to Vienna in this post;
...and this is well in line with the info in the Master Link and Beolink handbooks;
The 1611 can act as an audio master whereas the earlier 1614 cannot.
The easiest solution may be a 3.5mm mini jack to aux.link cable, which you could connect either directly to a computer, or to a Bluetooth audio reciever. I personally use an apple airport express for AirPlay. Of course you won't be able to control transport with your remote in this setup, but it works and is stable.
In a compatible system you might consider a Beoport, but I'm not sure your overture is compatible.
Luke Spadavecchia : In a compatible system you might consider a Beoport, but I'm not sure your overture is compatible.
No, it's not compatible - have a look here: https://www.beoworld.org/faq_view.asp?id=20
The oldest N.MUSIC compatible system is the BS3000.
You could use a Beoport/PC2 as an audiomaster to supply a Masterlink system, but you would not be able to add either the Overture or the BC2300 to the 'network'.
I would keep it simple as suggested by Luke and use either airport express (as I do) or a direct connection.
(A useful summary of converters from Luke, but I do not think that the 1614 was a US/CDN version. It is simply the older version of the 1611. The 1613 was the US/CDN version of the 1614)
