Aux input control with remote.
This post has 4 Replies | 0 Followers
RubEric2006
Posts 2
RubEric2006 Posted: Tue, Apr 2 2019 4:52 AM
I have added an auxiliary audio input to my treasured Besound 4000/Beolab 8000 system.  I can connect to this  input using the AUX button on the control panel but there is no such button on the remote.  How do I/can I configure the remote to give me AUX control?
Tia.  Eric
TWG
Posts 1,672
TWG replied on Tue, Apr 2 2019 9:47 AM
You can access "A.Aux" via "List" on a Beo 4 remote.
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Apr 2 2019 9:51 AM
And if it's not under the LIST function, you can add it as follows:
- Press Power and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows A.AUX. then GO.
- A.AUX should then be listed under LIST.
Johan
Bolsward, NL
Posts 450
Johan replied on Tue, Apr 2 2019 9:58 AM
When your remote has an AV button, also pressing first AV and then TV should do it. At least this works with a BeoMaster 5500 at my parents in law.
RubEric2006
Posts 2
Guy:
That did it!!  Thank you VERY much.Smile
Eric
Page 1 of 1 (5 items) | RSS
