Connecting Beosystem 3 to old Avant
This post has 4 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Thu, Apr 11 2019 2:07 PM
Dear members,
can you connect the Beosystem 3 to an old Avant 32 RF CRT and if so, how?
Thanks!
Kai
DMacri
United States
Posts 881
DMacri replied on Thu, Apr 11 2019 3:39 PM
To do so you would need to covert the DVI or HDMI output to match the composite, component, or Scart input of the avant with an external box.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Manbearpig
Posts 908
Thanks a lot. Two more questions:
1) Will this lead to reduced picture quality compared to using an external receiver and connecting directly to the Avant via Scart?
2) I'm still not quite clear (even after reading the manual) how to connect Audio and Video in such a setup. I can directly connect the Avants IR out to the IR in auf the Beosystem 3 via cinch? How do I integrate an audio system, say the Beosound 9000? Connect via Masterlink to the Beosystem 3? How should I program options then? Beosystem 3 in 0 and Beosound 9000 and Beovision Avant in 1?
Sorry for asking, but I find it not obvious.
Greetings,
Kai
Rob - Danish AV
Melbourne
Posts 376
Are you wanting it for surround sound? or utiizing hdmi? or?
you can get a Beovision 7-40 MK3+ for probably less than a Beosystem 3..
Manbearpig
Posts 908
Manbearpig replied on Fri, Apr 12 2019 12:32 PM
There are several reasons. I honestly don‘t want to replace the old Avant CRT RF if reasonably possible. Kai
Page 1 of 1 (5 items) | RSS
