BeoCenter 7700
Beonewb
Posts 11
Beonewb Posted: Thu, Apr 11 2019 10:00 PM
Hi Beoworld users,
The aluminum cover of the tape and programming section on my BeoCenter 7700 no longer closes flush with the turntable cover. The lower left hand corner sticks out just enough to be noticeable.
Does anyone know how to adjust or fix this problem?
Thank you for your help,
Beonewb
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Apr 12 2019 12:12 PM
Missing rubber foot under the Beocenter?
Broken hinge at the rear?
Beonewb
Posts 11
Beonewb replied on Wed, Apr 17 2019 4:17 PM
Hi Martin,
Thanks. It was a missing rubber foot.
Do you have any idea where I can get one?
Thanks again
Robert
Dillen
Posts 13,191
Dillen replied on Wed, Apr 17 2019 5:47 PM
They will all be brittle and crumbly by now.
Remove them all and put self-adhesive felt pads instead.
the_o_master
Posts 856
Beonewb:
Robert
As Martin said, remove them all and put 4 new foots, for example these or these.
Theomaster
Vintage Bang & Olufsen
Beonewb
Posts 11
Beonewb replied on Thu, Apr 18 2019 1:53 PM
Thank you very much to you both.
Regards,
Robert
Page 1 of 1 (6 items) | RSS
