Beogram 1700 cueing issue
This post has 4 Replies | 0 Followers
mdockrell
Dublin
Posts 32
mdockrell Posted: Fri, Apr 12 2019 7:24 AM
Received this yesterday. Plays beautifully. Particularly good midrange and treble. Is bass light which I like as am not a bass fan. To be fair it is running through speakers which are bass light and really need a subwoofer. Will test it with better speakers soon.
It has one small issue. The automatic cueing is a fraction off and the needle lowers on the edge of the record and sometimes slips off. Not a major issue for me as I just keep my finger in place to nudge it correctly, However, as this is meant for my children I would prefer it to be perfect as they will be more careless. Is there any easy fix?
mdockrell
Dublin
Posts 32
mdockrell replied on Sat, Apr 13 2019 12:29 AM
The weight hadnt been properly set - corrected that and now cues perfectly.
mdockrell
Dublin
Posts 32
lawrencejmcook
Posts 742
Very considerate of you to post the solution. Thank you. Smile
mdockrell
Dublin
Posts 32
mdockrell replied on Sat, Apr 13 2019 11:44 AM
cheers - well I always think someone else may have the same problem at some point. Great when it is an easy fix. I should add that I have received really helpful advice with any problems so am always happy to help out, if I can.
Page 1 of 1 (5 items) | RSS
