B&O Customer Support Not Sure - Where Do I Go Now?
Quarkrad
Posts 3
Quarkrad Posted: Fri, Apr 12 2019 5:36 PM
I asked if I could connect a Chromecast stick or Amazon Fire Stick to my Beovision 6 TV (I have the earlier one without an hdmi port).  Could I use a hdmi to dvi+audio adapter to this non hdcp compliant TV?  Their first response was that it should work but there are not many B&O recommended adapters.  So .... I emailed them back asking what adapters were approved.  Their second response was to tell me there were no recommended adapters having originally telling me there were(?!!).   I'm a bit stuck now - any advise appreciated.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Fri, Apr 12 2019 6:27 PM
Can't see what it wouldn't work with a Chromecast or with a Fire Stick; pick what you prefer. If the BV6 can't juice the CC or FS then buy an external power supply.
I myself use the CC together with a BV10 and added Google's power supply which provides ethernet capabilities as well. I just want to have things hard wired if possible.
Stoobietoo
Exeter, Devon, UK
Posts 692
I'm using this setup to connect my FireTV to my Beocenter1 (Non HDCP compliant I assume) It only has scart connections and have no issues at all.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Apr 14 2019 4:46 PM
Amazon Fire TV stick will work on BV6-26 with DVI socket.
You'll need an HDMI - HDMI audio extractor, an HDMI - DVI cable and a stereo rca cable.
If you want to control your Fire TV stick with your Beoremote (Beo4?) you have to use the BV6 PUC.
You' need a special USB adapter
https://www.amazon.de/dp/B00V9XS4V4/?coliid=I1633OHB5NLN3H&colid=222ZGC2BDNTFK&psc=0&ref_=lv_ov_lig_dp_it
a Flirc USB and an IR transmitter cable for the PUC. Program the Flirc to one of the built in PUCs of the BV6.
Hope this helps
Stefan
Page 1 of 1 (4 items) | RSS
