MrAndersen: Shuffle on Moment: I don't know, it is on a separate branch not sure how often we update. Let me check Missing multiroom icon is a bug. I will report it. A1 missing OneTouch, looks like a bug as well. Reporting that as well
Many thanks MrAndersen.
And sorry to repeat myself, but the bug detailed here https://archivedforum2.beoworld.org/forums/t/36860.aspx needs attention too in IMO.
Summary: When I empty the play queue of the multiroom master, I'm expecting ALL products in the multiroom group to stop playing music and it is not the case.
MrAndersen:The error has been found and fixed for the A1. The version was strangely formatted, this is fixed. Building a new version later today
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
mbolo01:Summary: When I empty the play queue of the multiroom master, I'm expecting ALL products in the multiroom group to stop playing music and it is not the case.
@Jean: Yes the virtual keyboard is on our backlog, I will look into if we can fast track it
@Mbolo: That seems like a product issue. I will forward it to them
Carolpa: So true, but in my case only the actual track is finished in the linked products. Then all are silenced and waiting for a new queue.
Correct, only the currently playing track continues to play on some products while others have stopped as expected. Good point to help for a fix.
mbolo01: Carolpa:So true, but in my case only the actual track is finished in the linked products. Then all are silenced and waiting for a new queue.Correct, only the currently playing track continues to play on some products while others have stopped as expected. Good point to help for a fix.
It is a product software / NL issue. The same phenomenon if one uses Beolink 2 / Beoliving.
MrAndersen: @Jean: Yes the virtual keyboard is on our backlog, I will look into if we can fast track it
Thanks a lot! That will be a very useful addition!
Jean
Fansastic:Mr Amderson, I recently experience problems with my NL/ML converter in multiroom session. The BLC keeps dropping out. Tried all kinds of settings, enhanced the time delay on the Moment but no result. My setup when dropping out is experienced: - BS Moment playing Deezer or TuneIn, connected to speakers of Horizon (Speakers on Horizon through Wisa) - BS3000 with speakers through BLC Might this be something in the app? I never had such many drop outs and the BLC is currently unusable to be honest. Thanks for your review!
People have experienced problems with Moment after a recent update.
Look here
Maybe your problem is related to that update?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Does anyone know if Tone Touch always been available for the Beosound 1?
Noticed that its now available in my Beosound 1 GVA.
beojeff:I’ve been having the exact same problem! It stated just after the recent Moment update.
Quick update with 2.6.0 and HW 1.20.31364 : I have seen no new bug but my radio bug is still there :
Imagine you have a TuneIn favorite list of 10 stations. If you go from any station to any other station using the arrows, there is no problem. For instance if you are in your 5th favorite and want to go to the 4th, you can with the left arrow, and right arrow gives you the 6th.
Now the problem is when you go to your last favorite : from 10th to 1st is ok, but now you're stuck and can only go to 2nd and not back to 10th. The circular playlist is imho the way to go, it was always working like that but the circle has been cut around 3 to 4 HW updates ago and doesn't seem to be a feature that will come back. (I've contacted the support team with the feedback button but never got any answer)
What do you think?
diisign.com
Hiort:Does anyone know if Tone Touch always been available for the Beosound 1? Noticed that its now available in my Beosound 1 GVA.
TT is only supported on the 2nd gen BS1 and it requires an update on the product due next week. The update next week should also fix the repeat bug, double checking that currently
I will contact the product team regarding the Moment issues you are describing
Thanks for the update, what about the nom-circular TuneIn favorites?
MrAndersen:The product connection should always update, we haven't tried turning them off though. It should be based on an actual connection to the product. I will try to reproduce it like you describe
I did more tests, with more products, confirming the issue:
When the app is active in foreground: taking the product's power cord off results in the product being greyed out in the app home page after a couple of minutes and product is shown active when power is plugged back
When the app is running in the background, that you physically power off a product in the meantime, bring the app back to foreground a couple of minutes after, powered off product will still show as active.
Since the last sw-update in Beoplay A6 (sw 1.20.31365.1217223635) and the new sw in the B&O-app (2.6.0 and 2.6.1) I experience problem with the B&O-app when using my two Beoplay A6.
I have two Beoplay A6 in two different rooms. One in the room called "Arbetsrum" and one in a room called "sovrum".
I will start in detail how the problem occours:
- If I mark the "arbetsrum" in the APP and close the app and start up the B&O-app again the following happens:
1. In the "now playing screen" all sources in the sourcelist to the right is shown and the Beoplay A6 in the "arbetsrum" works perfect with coverart and timeline and so on....
2. If I in this situation change the marking in the product-meny in the APP to "sovrum" then no sources is shown in the "now playing screen" in the sourcelist to the right. If I in this situation start playing Deezer in the "sovrum" there is no coverart and no timeline.
3. If I close the APP and start it again then "sovrum" is still marked in the product-meny in the APP. In this case all sources is shown in "sovrum" in the now playing screen and in the sourcelist to the right, and the "sovrum" Beoplay A6 works perfect.
4. If I in this situation change marking in the product-menu in the APP to "arbetsrum", then this Beoplay A6 is missing all sources in the sourcelist that you find in the right in the "now playing screen". If I start Deezer in "arbetsrum" then all coverart and timeline is missing in the "now playing screen".
Summary: I think that when I start up the app, the APP misses to connect correctly with one of the Beoplay A6 everytime the app start up. The A6 that is NOT marked when starting up the APP, is the A6 that also fails to connect correctly with the APP. The marked A6 will connect perfectly with the APP and work as it should. If I change marking in the product menu to the other A6 (to the one where sources are missing) and close the App and start up the APP again, then this A6 works perfect.
I can not be the only one with this problem. Maybe this is just A6-related problem and not so many people have two A6:es.
Am I the only one who is experience the software-bug above?
Best Regards Martin Ström
SWEDEN
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Martin:Hi, Since the last sw-update in Beoplay A6 (sw 1.20.31365.1217223635) and the new sw in the B&O-app (2.6.0 and 2.6.1) I experience problem with the B&O-app when using my two Beoplay A6. I have two Beoplay A6 in two different rooms. One in the room called "Arbetsrum" and one in a room called "sovrum". I will start in detail how the problem occours: - If I mark the "arbetsrum" in the APP and close the app and start up the B&O-app again the following happens: 1. In the "now playing screen" all sources in the sourcelist to the right is shown and the Beoplay A6 in the "arbetsrum" works perfect with coverart and timeline and so on.... 2. If I in this situation change the marking in the product-meny in the APP to "sovrum" then no sources is shown in the "now playing screen" in the sourcelist to the right. If I in this situation start playing Deezer in the "sovrum" there is no coverart and no timeline. 3. If I close the APP and start it again then "sovrum" is still marked in the product-meny in the APP. In this case all sources is shown in "sovrum" in the now playing screen and in the sourcelist to the right, and the "sovrum" Beoplay A6 works perfect. 4. If I in this situation change marking in the product-menu in the APP to "arbetsrum", then this Beoplay A6 is missing all sources in the sourcelist that you find in the right in the "now playing screen". If I start Deezer in "arbetsrum" then all coverart and timeline is missing in the "now playing screen". Summary: I think that when I start up the app, the APP misses to connect correctly with one of the Beoplay A6 everytime the app start up. The A6 that is NOT marked when starting up the APP, is the A6 that also fails to connect correctly with the APP. The marked A6 will connect perfectly with the APP and work as it should. If I change marking in the product menu to the other A6 (to the one where sources are missing) and close the App and start up the APP again, then this A6 works perfect. I can not be the only one with this problem. Maybe this is just A6-related problem and not so many people have two A6:es. Am I the only one who is experience the software-bug above? Best Regards Martin Ström SWEDEN Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 5 front (sw 3.30a), Beolab 3 rear, 2xBeoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Hi Hjort,
good to hear that someone else have same problem. Can you Please also report your problem to customerservice so We get a fix for this.
Best Regards
Hiort:Another problem: M3 is the source and M5 and BS1 have joined, but BS1 show no multiroom symbol.
Hiort:One more thing I have noticed: The standard volume in the app does not match the setting in the web interface. This is what the web interface show:
mbolo01:This one is old too. Sometimes it is fixed, sometimes it comes back. Unfortunately for us, B&O have serious regression tests gaps, if they do any, since the beginning of the app development BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
Hiort:Thanks for letting me know.
Hiort:Volume indication in multiroom ....
Hi there Mr.Andersen.
Have a problem with the app right now.
Multiroom is not working for me properly.
Airplaying from a MacBook Pro to a BS2 - works ok.
Use the app to add other rooms, an A9 MKII and my lounge BS4/BV12+speakers.
Usually no problem.
The other rooms join the stream if I add them (+) on the multiform tab - but the multiroom page shows no change, i.e. as if they are not added.
So I can then not remove, control volume etc for the added rooms using the app.
The app says that the source does not support multi-room, even though the other rooms have actually joined the stream.
Anything you can suggest?
Sandyb: The other rooms join the stream if I add them (+) on the multiform tab - but the multiroom page shows no change, i.e. as if they are not added. So I can then not remove, control volume etc for the added rooms using the app. The app says that the source does not support multi-room, even though the other rooms have actually joined the stream.
I'm facing the issue sometimes too, completely closing the app and relaunching it provides a correct status back, so there is an obvious status and control update with this release.
Hi guys
Seems there is some issues in multiroom, The problem for us in this area is that we basically show what the products tell us. I will look further into it
@mbee: non-circular tunein favorites is a product issue, I will pass it on
MrAndersen:Wrong representation of volume in the multiroom view for A6
Hi MrAndersen - M3 is also impacted by the volume representation, if that helps finding a common denominator
The bug has been found. We did a startup optimization for large setup, this caused some products not to connect. The fix is in 2.6.2 currently in beta test review, should be with the beta testers tomorrow depending on review time
I confirm that the sw 2.6.2 (B&O-APP) now works perfect.
Good work Thomas!
Best RegardsMartin Ström
Martin:I confirm that the sw 2.6.2 (B&O-APP) now works perfect.
