Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Best bet is an Avant 55 first Gen or an 11-55.
Anything else newer is android based
Perhaps title could have been 'our NON B&O TV died"
A couple of observations....
I think that’s a lousy offer from JL. I would be demanding the £1300, or a TV of the same value (which will obviously cost JL a lot less)
Would a new LG / Samsung not be a better propersition in terms of picture quality? I do take your point about sound quality, but a good quality sound bar / base fixes that.
I’ve never been a fan of B&O TVs... Just too overpriced.
Cheers
Nigel
If you look here you can see that moxxey will offer his BV 11-46 for £1500.
I think this is relay good deal.
Vintage Bang & Olufsen
Even for a non B&O TV fan, that does look very tempting!!!
Rob - Danish AV: Best bet is an Avant 55 first Gen or an 11-55.
I really couldn't recommend an Avant 55 1st gen. I had one and it lasted 3 months. It just looked like a 'first gen' 4K panel to me.
11-55 I would recommend. I owned one and loved it. Not 4K, but not needed for 55". You can use the most recent modern BeoRemote, hide older Apple TVs in the case and even hide a Sky box at the rear if the TV is in the corner of the room.
the_o_master: If you look here you can see that moxxey will offer his BV 11-46 for £1500.
He *might* have a 11-46 for sale . If/when I do, I'll pop it on the 'for sale' section as per forum rules. It will be approx 5 weeks from now.
What's happening here is I'm having to move out of my current apartment in June as the landlord wants to revamp the building. So, making plans around this. Part of me wants to move to the US and work with my business partner out there and setup officially (right now we manage the US from the UK), but then there's the dreaded visa issues (spoke with an immigration lawyer yesterday and she says it's becoming immensely hard to get setup in the US under the current administration) and the other part of me wants a simple move within the same town - if that happens I'll take the 11-46 with me.
If anyone has any experience or advice on getting a visa to help a business partner setup in the US, let me know!
moxxey:I really couldn't recommend an Avant 55 1st gen. I had one and it lasted 3 months. It just looked like a 'first gen' 4K panel to me. 11-55 I would recommend. I owned one and loved it. Not 4K, but not needed for 55". You can use the most recent modern BeoRemote, hide older Apple TVs in the case and even hide a Sky box at the rear if the TV is in the corner of the room.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael: I still have my Avant gen 1 and don’t see any first gen issues. It’s not a backlit display and you come from plasma world so I guess that’s what you are referring to?
The first gen Avant I had was awful. I found it to be ultra-bright (even brighter than the BV11), had panning issues under HD and so on. Also, SD looked terrible as I guess it was up-scaling to 4K. And quite a few British channels/programmes were still in SD in those days! Granted 4K might have been beautiful, but there was zero 4K apart from a few test videos on YouTube.
But, it was one of the first out of the factory, so was a true early model. Swapped it for a BV11-55 which I kept for quite a while. Just felt that it was a classier TV and the panel was more settled than the Avant.
The BV12-65 is a relatively recent (2 years or so) purchase, so only used to plasma long after the Avant 55.
IMO one should never buy the tv, that the wife wants.....unless that is for her own room 😁
Buy her a decent, big tablet - and get the tv that you want (and can afford, of course).
Please don’t forget - a BeoVision is more than just a tv!
On the other hand, if what you are looking for is just a tv, you might do as your wife tells you - at least then there will be peace in the house.......for a while
mM.
@ seethroughyou:If your wife has humour have a look in your wife's wardrobe, choose some of her expensive clothing and ask why she can't wear a 10$ shirt instead when arguing about the TV. ;)She likes to dress up? And so does the Panasonic/LG tech, too: It wants to be dressed in some nice B&O clothing spiced with that B&O extra tech. Explain the positive sides for her when watching her favorite content on a Beovision. And yes, I see it the same way Millemissen does: Get the TV you want... otherwise you'll be angry or worried everytime you have to use that thing that you don't want and like.
We (B&O Lincoln) have a MK1 BeoVision Avant-55" on a motorised floor stand, beoremote one, (sold originally Oct 2014) 1 year warranty. Can supply to if collected for £2600 or + £200 if you need an engineer to deliver it to you and do a basic set-up. Let me know if of interest. lincoln@bang-olufsen.co.uk
Thanks, Michael
4 years ago I bought the Beosystem 4 as I have a number of B&O speakers that I wanted to keep in play. My TV at that time was a Toshiba 34" tube that I had for over a decade. My B&O dealer said I could get an Advant 55" for what I was paying for the Beosystem 4 but I stuck with the Beosystem 4. Due to TV placement issues I ended up waiting 2 years before replacing the TV. I'm glad I went with the Beosystem 4 option. True the Beosystem 4 doesn't do 4K but most material I watch (Broadcast TV with a ChannelMaster DVR+) isn't 4K and can be fed directly into the Beosystem 4. I do have an Oppo UDP-203 that plugs directly into the TV with an additional hdmi output that feeds the audio to Beosystem 4. With the Beosystem 4 option I was later able to buy a Sony A1E OLED TV and incorporate it into my B&O sound system.without issue.
