The leds are there to give a status about the PSU. So, in this case the 5SB powerline is dead.
I suspect more than just a capacitor.
Hi
do you think motherboard is broken ?
Nope, the powerboard underneath the diskdrive.
will try to change with other one to check :)
Hope it can be fix.
Beobuddy
update..
Led smd had bad solder that is why not working.
After all chenges at the end, problem is on motherboard.
let's go on :)
