Mikipidia:I finally got new cables but still no luck, again it's a lot less but I think either in the tv or in the master there is a bad ground somewhere. Cat7 between the speakers is fine and so are other cat 5e or cat6 cables, but between the tv and the master is where the problem is... cat 7 gives ticking, cat 6 gives ticking and an electro sound when changing volume and or anything speaker related(data ground) and cat 5e gives the least of ticking and my cheapest cat 5e cable doesn't give any but the most electro sound. Spoke with Willie and he also confirms that's a bad ground on the data channel, so now we have to find out if it's in the tv or in the master speaker. I don't want to burst your bubble, but this is what I am dealing with
What exactly is the problem ?
Are these cables for PL?
Probably a game changer for B&O.
@BEOVOX141
Sorry I missed it, but it seems like i had a cable issue as in the shielding broke or something but even with the new cables i had the same weird issue and then all of a sudden it was gone. So in short they're fixed now, but we have no idea what the problem was(is/has been) as nothing has changed but the issue is gone. so yaaay and
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
You're very welcome! It's nice to share our passion
Hi
Unfortunately, I'm not the owner of Breolab 50 or 90, nor Beolab 5
But I listened to these..one of the songs on Beolab 50: https://www.youtube.com/watch?v=gtwUyDPXROQ
Amazing ... what a divine sound, The room is very acoustic next to a bottle of 25 year old cognac and a pleasant company :)
The entire album, Famous Blue Raincoat is brilliant.
Try Song of Bernadette on the same album
Razlaw:My 50s arrived😀 Still waiting for microphone 🙁
So, no karaoke yet?
Congratulations, hope you enjoy them.
Jeff
Jeff:So, no karaoke yet? Congratulations, hope you enjoy them. Jeff I'm afraid I'm recovering from the BeoVirus.
Duels:How exciting. Enjoy. Can we have a pic?
Razlaw: Duels: How exciting. Enjoy. Can we have a pic? Have lots of ugly outlets behind the 7 but using them looks horrible. Am trying to come up with a way to hide everything.
You did the hard part.
White braided sleeve you can find see below. You can buy shorter mains cables in white very cheap from Amazon. If you don't want to pay electrician to move your outlets you can create and paint a very correct-size false wall panel to channel cables from floor. And I WOULD use a surge protector. Good luck.
https://www.electriduct.com/Self-Closing-Braided-Wrap.html
poodleboy:You did the hard part. White braided sleeve you can find see below. You can buy shorter mains cables in white very cheap from Amazon. If you don't want to pay electrician to move your outlets you can create and paint a very correct-size false wall panel to channel cables from floor. And I WOULD use a surge protector. Good luck. https://www.electriduct.com/Self-Closing-Braided-Wrap.html
Razlaw:Some progress with cables....
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Yendys:Looks really good and very well hidden
Esax:They forgot that feature. Reset and do it all over. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Esax:You are a clever guy. Not even my dealer knew that. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Hi Raslaw,
Congratulation to your new Beolab 50. I must ask you if you have had any problems with the Slave-speaker looses connection with the master-speaker?
I have had a lot of problems with this. In two month it has happened 9 times!.
I would be nice to know if you have had any trouble with your new speakers.
Best RegardsMartin
SWEDEN
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Hi again Raslaw,
Did your Master speaker flash orange fast those two times.when the speakers stoppet working?
/Martin
looking good
The front grill shows an amazing skill of craftsmanship . Simply wonderful done.
But I really don’t like that you can see the drivers. Some cloth behind the grill would be (for me) the solution.
I’ve seen the production of several aluminium parts at the factory last august, but that is intriguing. So much care for details you normally don’t know or are aware off.
Beobuddy:The front grill shows an amazing skill of craftsmanship . Simply wonderful done. But I really don’t like that you can see the drivers. Some cloth behind the grill would be (for me) the solution. I’ve seen the production of several aluminium parts at the factory last august, but that is intriguing. So much care for details you normally don’t know or are aware off.
They look great
