Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Now that is interesting - not that I (would) use that much.
For music I basicly use Spotify Connect and that has been working that way forever.
But it shows that they are still working on the integration of a new product/the Core and an ‘older’ tv like the BV11.
Maybe I should update my Essence (to the newest sw) to see if that does the same with my Avant and the V1.
Anyone else has made this observation?
Are we not sure this is something Apple have update in Airplay, so when Airplay in use, the meta data now transfer over.
And this is nothing about B&O firmware
andybandy: Are we not sure this is something Apple have update in Airplay, so when Airplay in use, the meta data now transfer over. And this is nothing about B&O firmware
No - otherweise it would work with my setup....which it doesn’t.
andybandy:Are we not sure this is something Apple have update in Airplay, so when Airplay in use, the meta data now transfer over. And this is nothing about B&O firmware
I made a thread about three weeks ago with a question of the changes in the SW 1.19 to 1.20 (for the Essence)
https://archivedforum2.beoworld.org/forums/p/36768/275127.aspx#275127
Noone mentioned that, then!
Now I have just updated to the 1.20/the latest on the Essence.
And what Dyssegaard describes works well there, too (and via the M3 as well).
My Essence is not integrated, but connected to the Avant (and the V1) - but this does not seem to change anything.
Maybe they are preparing for the features of the coming remote, most likely.
But also for the metadata that (apparently) will be shown on the Harmony when in Audio Mode.
Below a couple of examples from using different apps (the TuneIn app and the DR app) with AirPlay to the Essence joined in by the Avant.
For my taste there should be a little more information on the app itself - as also seen in the screenshots of Dyssegaard.
A cover pic of the actual played track would be nice.
