I looking for a picture of a wall mount BS9000. I founded only a wall plate. How does the wall profile 2569471 is (pictures, I already have the service man drawing)?
I need to made wall profile. Do you have any idea ?
Could somebody help me ?
I suggest you look HERE
Regards Keith....
Thanks Keith
But the views are a little more clear than service manual. But it's not enough clear...
I someone has a real picture....
Dear Silou,
I found this, it seems, that wall part is not to hard to produce from 2-3mm metal plate.
and this
and this, view from wall side (wall profile inserted/locked in rear plate)
Perfect!!!!
BS9000 is only suspended by his weight? No locking ?
It's not very strong!!!
Thanks !!!
Hook (on there wall plate) and groove (on the rear pannel).
