Beosound 1 - deactivating the Lamp
ChrisBerlin
Posts 36
ChrisBerlin Posted: Thu, Apr 25 2019 9:30 AM
Hello,
has anybody an Idea how I could deactivate the small Lamp under the Speaker at the top of the Beosound 1? The Beosound stands in my bedroom and this lamp is to bright in the night.
Chris
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Apr 25 2019 10:00 AM
Same here, but I don’t know any way to do it
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Apr 25 2019 10:12 AM
Unfortunatly not.
That is the same with almost all the speakers that B&O insist to have a lamp glowing.
Should be a simple thing to introduce a "night mood".
Email B&O and let them know.
ChrisBerlin
Posts 36
I don‘t know why the lamp has to be on although the Beosound isn’t playing ...
ChrisBerlin
Posts 36
Hiort:
Unfortunatly not.
Is it possible to disconnect the lamp?
Michael
Sweden
Posts 2,578
Michael replied on Thu, Apr 25 2019 10:28 AM
Hiort:
Unfortunatly not.
On the Beolab 20, Beolab 18 etc the light goes out after a few seconds and only lights up as it turns on or off or is in safe mode. The older models these replaced however always had a light.
On a side note. When Apple introduced iMac G5, the first flat iMac (without a globe foot) they got complaints from students because their dorm rooms would be to light with the iMacs sleep pulsating light indicator. Apple responded by a firmware fix that allows the illumination to shine less bright when the room light level is less than in daytime, using the light sensor primarily used (and only for, before) the monitor. Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Apr 25 2019 11:03 AM
ChrisBerlin:
Hiort:
Unfortunatly not.
It is not possible
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Apr 25 2019 12:03 PM
Hiort:
Should be very simple indeed as they already control the color and the intensity
Page 1 of 1 (8 items) | RSS
