Beosound 9000 mk2 replacement laser
This post has 9 Replies | 2 Followers
Clivo
Posts 5
Clivo Posted: Wed, May 1 2019 9:29 AM
Hi - does anyone know where I can get a replacement laser for my Beosound 9000 mk2?
I live in Australia but will get it from anywhere.
Thanks!
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Different drives are placed in a mk2. Even a mk3 (latest version) is possible, which requires an original one.
Most of the time an ebay version will be sufficient, but to be sure, try to make a photo like below.
Maybe then we can see which laser your mk2 needs. Keep in mind that changing means changing the actual pickup element. General drives don't have the black cover just above the laser.
Clivo
Posts 5
Clivo replied on Wed, May 1 2019 10:54 AM
good advice - thanks
solderon29
U.K.West Midlands
Posts 764
As Beobuddy states,there were different cd player mechanism's fitted across the range,and your's may have been replaced by another type too as a service solution.
You will need to remove the mechanism,and look for an indentifying label "VAM1205" or "VAM1250".
I understand that both type's are being manufactured again as pattern parts,but you need to be careful when ordering as the majority of VAM1250 versions on offer are not compatible with B&O.
Nick
Clivo
Posts 5
Clivo replied on Thu, May 2 2019 12:23 AM
thanks Nick - the label is VAM 1250/21, so I'm assuming that an replacement of this will do the job, yes?
Clivo
Posts 5
Clivo replied on Thu, May 2 2019 12:24 AM
solderon29
U.K.West Midlands
Posts 764
No,that's the tricky one!There are loads of VAM1250's on offer,but my experience has been that they either don't work at all,or work only spasmodically.
As the laser works hard in the BS9000,you need the correct item.
I've bought these laser's from a specialist here in the U.K. and found them to be ok.The company can  also repair the mech if you send it to them.
They are used in other brands too,and due to demand,they are being made again.
I have no commercial connection with this company,but I'm happy to recommend them.
I'll send you an e.mail with further details
Nick
Clivo
Posts 5
Clivo replied on Thu, May 2 2019 11:01 AM
great - thanks Nick Smile
rubli
Posts 4
rubli replied on Thu, Jan 7 2021 1:41 AM
Hello
would like to know where to buy a replacement laser for the MK2 unit (2563), the Laser unit is labeled as VAM1205
thank you in advance
Alexander
matador43
Posts 1,373
China, eBay, around 15€.
Replacement rocess is well documented on the forum.
Good luck!
Page 1 of 1 (10 items) | RSS
