Configuration NL/ML - old /new
This post has 15 Replies | 2 Followers
Wild Ruedi
Zürich Switzerland
Posts 102
Wild Ruedi Posted: Wed, May 1 2019 9:25 PM
Hello
My set up is: Beosound Ouverture with ML to various rooms. In the same room I have BV 11 and Beolab9,
The speakers are connected via Almando switch. New I would like to integrate Beosound Moment to listen to web radio. I have got ML/NL converter and delay box.
My worries are how to connect and how to setup the system to work satisfying. The remote control should be able to serve the Ouverture, for the other rooms, and the Moment in the living room.
Thank you for any hint.
Regards Ruedi
BeoVision11, BeoVision10, BeoSound 5, BeoSound 3500, BeoLab 9, BeoLab 4, BeoLab 6000, BeoLab 8000, BeoSound 3200, Beosound Moment,NL/ML converter, delaybox, var.BeoPlay Speakers
f5434964
Austria
Posts 206
f5434964 replied on Thu, May 2 2019 10:16 AM
Hello!
i have a similiar setup with a BV Avant connected by ML/NL Converter to my ML system; as far as i remember the BV should be able to provide Net Radio; so maybe the Moment would not be needed...
best regards elmar
sorry for Spelling - iOS written
Millemissen
Flensborg, Denmark
Posts 14,680
Sure, the BV11 has a Netradio function built-in.
This can easily be distributed to ML-products like the Ouverture.....but you will need the NL/ML Converter for that.
Wild Ruedi
Zürich Switzerland
Posts 102
Thank you Elmar. I will try this setup, but I like the Moment for the mood wheel.
Wild Ruedi
Zürich Switzerland
Posts 102
Wild Ruedi
Zürich Switzerland
Posts 102
Thank you MM. I understand, that with NL/ML the signal will be available on old and new products.
How will I be able to select the sources trough say BS3500 in the kitchen?
f5434964
Austria
Posts 206
f5434964 replied on Thu, May 2 2019 11:32 AM
Not beeing at Home i can not provide and pictures; you can easily set up the Converter over any Internet Browser by using its IP address; you will find an on screen menu where you can set your available sources (separated NL and ML) - so be aware not to assign 2 sources to one command (e.g. Radio or CD); than you can easily Access any Source by Beo4 on your devices; I have connected my BL to the Avant so you can select sources on Avant as well
Millemissen
Flensborg, Denmark
Posts 14,680
Wild Ruedi:
This - as f5434964 wrote - depends on how the converter is programmed.
However to reach the NL sources on the BL3500, this much understand the commands that you use there.
There are different versions/sw versions of the 3500 - depending on how old it is.
Not knowing this - you will have to try out, what works.
Also some of the newer commands N.Radio/N.Music are reuses of older commands Phono/A.Tape2
Wild Ruedi
Zürich Switzerland
Posts 102
Understood, thank you. What do I need to connect if I use BV11 as Networkradio? NL/ML for shure but the delay unit? Anyway I shall start try and error methode.
Thank you all for your support. I will report  my experience.
Regards Ruedi
Millemissen
Flensborg, Denmark
Posts 14,680
Maybe studying this (old) thread can help:
https://archivedforum2.beoworld.org/forums/p/6073/135722.aspx
Wild Ruedi
Zürich Switzerland
Posts 102
Thank you! it is all a bit confusing in theory. But I hope, once set up and trie out, I will find my way.
At the moment I am waiting for an ML distributor to appear on ebay.
Beozip
Posts 368
Beozip replied on Fri, May 3 2019 6:54 PM
here you go to german ebay
https://www.ebay.de/itm/Masterlink-Verteiler-Bang-Olufsen/333107611228?hash=item4d8ec2c65c:g:0VQAAOSwFfJcgkyA
good luck
Wild Ruedi
Zürich Switzerland
Posts 102
Thank you for the information. Switzerland is customwise an island in the middle of Europe!
Therefore are various fees and taxes on merchandise from the outer space.
Maybe I go for a junctionbox witch I have already.
Regards Ruedi
Wild Ruedi
Zürich Switzerland
Posts 102
Hello
everything is connected and I can hear music! The system works somehow, but I find problems:
is the ML/NL the a-master?
the easy commands must remain like before: Radio, CD, Amem
BS Moment should play with different commands
How do I have to select the options?
sorry, for the hassel but B&O shops here are not a great deal of help.
Regards Ruedi
f5434964
Austria
Posts 206
Converter should be set to Video-Master
see private message
elmar
Wild Ruedi
Zürich Switzerland
Posts 102
Hallo Elmar
as I wrote to you with pm the setting needs to be A/Vmasterfor my arrangement. I do not want to connect video equipment anyway.
The setup works somehow, but I have problems with the
OPTION settings.
- BV11 + BS3200 in the living room
- BS Moment + BS 3500 in the office and ML/NL converter
- 2 more BS3500 in kitchen and bath
All connected with ML, separate Remote Beo4 in every room.
It works fine with the signal from BS3200 but I can not switch to BS Moment by pressing list- NLradio or NLmusic.
Any help will be greatly appreciated.
Regards Ruedi
Page 1 of 1 (16 items) | RSS
