Hello board
This is my first post here, so bare with me if I sound newbie-ish (that is what I actually am :-D)
I recently bought a super sounding beomaster 9300 with a couple of RL60.2 speakers and a Beo4-remote for our living room. It will replace my beomaster 3000-2 with beovox 4702, which will be moved into my sound-studio for mastering purposes (extremely well playing amp and speakers, but to much "in-your-face" for our living room).
When buying the 9300, I was extremely aware, that I did a proper speaker-test form 20Hz to 20000KHz, and also tested with different kinds of music and so on. Everything sounded great, and I was amazed by the sound of these plastic-like speakers and the amp.
So here comes the problem:
What I did NOT notice, on scene,was, that in the left speaker-channel, there is a litlle, barely noticable hizz/rattle-sound in the tweeter range, and in the right channel there is only the, barely noticable again, hizz-sound, also in the tweeter range. The two sounds doent follow the sound up, when I crank up the volume.
What I have tried so far:
- Switched speakers LR to RL. No effect.- Tried another input (Radio, Tape, CD and so on). No effect.- Switched to Speaker 1 outputs L and R. The left didnt work, and the right output played flawlessly without hiss.- Turned the amp off, and when current was out of the system, the hiss/rattle-sound came to a halt (after appr. 5 seconds.Any ideas or experience with this problem? Is it a common one?
Kind regardsTheDane
