Broom from rear BL 4000 conected to 10-46
liviu_o
Posts 157
liviu_o Posted: Fri, Nov 30 2012 7:03 AM
Hi!
I have a 10-46 conected to 2 BL 8000 and 2 BL 6000 ( as rear). Since the distance is quite long to rear speakers I have them interconected ( BL 6000). So far so well, everything was working well.
Yesterday I tried to switch the BL 6000 to a pair of BL 4000 using same type of conections and I received a broom from the speakers and a "pop"everythime I change something.
Can you help me why is it happening?
Thank you!
P.S. I changed the type of speakers in bv 10 setup.
liviu_o
Posts 157
liviu_o replied on Fri, Nov 30 2012 3:55 PM
Nobody encountered this situation?
Razlaw
Posts 4,345
Razlaw replied on Fri, Nov 30 2012 8:10 PM
Are the 4000s newer ice powered versions whereas the 6000s are older non ice powered? If so the cables may be the problem. I have a similar problem if I try to connect my Beolab 9s as rears using the same cables I have for the current (older version) 4000s.
Page 1 of 1 (3 items) | RSS
