mawheele:You either need a BR1 to update them
mbolo01:You meant a TR1 (Transmitter 1) BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
Duels:Are they automatically updated if they are connected to a transmitter 1?
The firmware on Beolab's connected via WISA via a TR1 - are NOT updated automatically over-the-air.
There is a firmware update procedure which involves downloading the latest firmware onto aUSB stick, which is stuck into the back of the TRA, re-booting the TR1 into a mode which will send the firmware to the WISA-connected speakers.
It's not for the faint-hearted, as there's no screen on the TR1, so it communicates though a series of coloured/flashing LED states. It takes quite a bit of time too, and if interrupted midway, you can brick your speakers!
If you have a dealer nearby, I'd recommend a service visit for peace of mind.
I was suffering dropouts, and the new firmware fixed it. There's no way of telling what firmware you speakers have without the dealer service tool (I think)
T
Fansastic:I’ll try to separate them, maybe they interfere when close together.
mbolo01:B&O recommends at least 1m between a wpl transmitter and a receiver. I guess having two RCV too close may create some issues. That said .... one of my BL18 is less than 1m from my TR1, my other 18 is less than 1m from my 19, my RCV1 are located between 8 and 9m from my TR1, sitting on the floor .... and I have no drops or very rarely on my 18 which are more or less horizontally aligned with the TR1. Moving the TR1 a little bit fixes the drops. I had more issues when i had my WiFi on 5GHz and before the latest BL18 software. I never had drops on my 8000 connecté to the TR1s BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
