Powerlink Cable Beolab 4000
This post has 1 Reply | 0 Followers
max666
Posts 4
max666 Posted: Tue, May 7 2019 9:04 AM
Hello all
I am building hifiberry DAC system to use with existing beolab 4000 speakers.
Hifiberry has RCA and beolabs also - it works fine with RCA cable (I have high quality RCA cable)
But I am looking a way to trigger power-on to beolabs (hifiberry DAC has 3.3V output).
Do i have to use full powerlink-RCA cable or is it possible to use RCA input on beolabs and just trigger power-on pin via powerlink cable? Will the beolabs accept power trigger if they are connected to RCA?
Has anyone tried that?
thnx :)
Bill Briscoe
Chicago, IL USA
Posts 165
I believe that Beolab 4000s will sense the signal from the line in (RCA) and turn on automatically, and when the signal is no longer present, turn off after a few minutes.
If you want more direct control of on/off via powerlink I'm sure Steve at Sounds Heavenly can make up a cable that has a powerlink end and a custom rca/power input from your device at the other end.
Page 1 of 1 (2 items) | RSS
