Hello,
So I noticed that the record was playing a bit too quickly, so I tried to adjust this by rotating the wheel on the bottom lefthand corner (see picture). Something clicked and now the record won't spin unless I turn the wheel all the way to the right, and then it only plays way too fast.
I'm hoping I haven't broken anything. Does anybody have any tips?
Jon
Most likely the speed changing mechanism has seized in dried lubricants.That's very common.
For fine tuning of the speed there is a adjust wheel on the left side of the Beogram 1203:
Vintage Bang & Olufsen
Ah, bother. Wish I'd known about that wheel before I started fumbling with the main speed setting. Hopefully I haven't damaged anything permanently. Will take another look tonight. Thanks all for the replies!
Hi Martin,
Is this fairly straightforward to fix? What's the process? I guess I need to open it up to take a look inside. A little nervous to do this as I have no experience maintaining turntables!
Jonathan
