Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Nice tip!
Is that a 46" or 55" you have there?
Does it matter for the space available?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:Nice tip! Is that a 46" or 55" you have there? Does it matter for the space available? Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
You win at living rooms
hostler:You win at living rooms
Hiort:Got inspired and did the same on my BV11-46. Worked very well: Now the cabinet under the TV is empty Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
Cool!
What is the piece made of? Plastic?; Hence you can easely take it off?
Reto:Cool! What is the piece made of? Plastic?; Hence you can easely take it off?
Aussie Michael:Even though the BV11 can’t handle 4K did you install the 4K version because it’s a quicker device ?
Aussie Michael:I find that the ATV4K runs hotter than previous gen (fans etc) Would it pay to turn the ATV 4K around so the bottom (fans) face outward ? Even though the BV11 can’t handle 4K did you install the 4K version because it’s a quicker device ?
Aussie Michael:Great news The ATV4K still doesn’t turn off though when I turn off my BV14
Same thing in my BeoVision 14-40. A bug in the PUC-table I guess.
Karel.
kuyttendaele:Same thing in my BeoVision 14-40. A bug in the PUC-table I guess. Karel.
Always use the right PUC
Millemissen:Always use the right PUC MM There is a tv - and there is a BV.
Sure!
I'll update my PUC tonight... But I'm also running the beta of tvOS... so probably 2 issues at once... tvOS should probably be out of beta beginning October (or at the latest 1Nov when AppleTV+ launches)
It seems the update didn't fix the issue of the power for me.
I even re set up the HDMI from scratch but no beuno
