Hello Beoworld,
I would like to enter the service menu of my Beocenter 2.
The Service Manual tells me to "press “menu” then press >> and within 3 sec. Press 0 0 GO" on the Beo4
I have done this a couple of times now but nothing happened.
I have tried it with the system on an in standby, I have also tried to do the corresponding command on the keyboard itself.
Generally the BC2 works fine.
Am I missing something or doing something stupid?
Thank you all in advance!
The only thing that happens is that it goes to A.Aux every time.
On your Beocenter 2: Press List, scroll down to "Setup", press >> and then "0" "0" "Go"... eh voilà: You're in the service menu. :)
Thank you!!
the service manual left out the scrolling to "Setup".
Beoworld is better than B&O itself :)
best wishes
Carlo
