looking for a kitchen TV instead of my BL2000. A set with ML and HDMI would be nice. SHMBO has rejected BV10, so I’m now thinking about BV 8-32. It’s a matter of space, as it’s not a very slim TV, so I have some questions:
- How many cm will there be from the wall to the tip of the speakers?
- How many cm will there be from the wall to the back of the TV (space for an Apple TV 4)?
- Is it possible (and easy) to have it to control the ATV?
- Is the wall mount fixed or can the TV be rotated?
A picture or two of such a set would be great!
/Thanx
Not the original wall mount, but this will give you an idea of size:
https://www.stbbrackets.co.uk/en-GB/product/beovision-8-40/beovision-8-close-wall-bracket-18-degree-tilt
I would go the 10-32 over the 8-32
The BV10-32 is a true wall mounted TV and looks the part. It’s compact yet practical
The 8 is getting old, likely to have an older TV tuner and doesn’t have 1080 resolution
BV10-32 anytime —— your SHMBO must be kidding.
Thank you for inputs and pictures!
I only need one HDMI (for use with ATV) and Master Link. No need for tuner.
But 23,5 cm will be a problem. Will do another try with SHMBO for the 10-32.
Cheers!
Agree that a BV10 is to be preferred before BV8.
I had both (BV8-32 and BV10-40) and BV10 is superior. The 10-32 has very nice proportions.
Lycka till!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Rob - Danish AV:I would go the 10-32 over the 8-32 The BV10-32 is a true wall mounted TV and looks the part. It’s compact yet practical The 8 is getting old, likely to have an older TV tuner and doesn’t have 1080 resolution
I like the look of 10-40 more than 10-32 (and 10-46) but I don’t know why.
Is the proportions between screen and speaker better on 10-40? Anyone agree, or is just me?
