Beosound 9000 Starup volume
kallem3
Posts 6
kallem3 Posted: Tue, May 21 2019 10:20 PM
Hello everyone, I thought I had it already some years back but seems I lost it - how can I adjust the startup volume of the Besound 9000, so that its not that loud when starting up?
many thanks, Stefan
Bill Briscoe
Chicago, IL USA
Posts 165
if you use the keypad, select all the settings you want, including volume, and then select ok, then ok again. The settings will be stored for the next time you use it.
Good luck,
Bill
Page 1 of 1 (2 items) | RSS
