BeoCenter 7000 turntable cover hinge, plus a dumber question
This post has 11 Replies | 2 Followers
Jack
Rochester, NY, USA
Posts 41
Jack Posted: Tue, May 21 2019 10:59 PM
Things are moving right along with the BeoCenter 7000 t1803 that I acquired recently. Martin has the tapedeck belts on the way and I got the tonearm adjusted so that it drops confidently into the start zone, no longer falling off the record half the time.
Poking around here, I saw numerous questions about the aluminum door over the control panel but no one asked about the plastic cover over the turntable. The cover on mine opens nicely but won't stay up. Hold it or drop it. I presume I'm not the only person lacking a third hand to hold the thing up while pressing the "turn" button and applying the record cleaner to the disc. Shouldn't the lid stay open?
My investigation has found two wire springs that don't seem to be doing their job. They are to each side of the lid, right and left. Should there be a third spring, in the middle? Checking the service manual, I'm unsure whether there is a hinge piece, similar to what the control panel door has.
Am I the only one with a sagging door?
Second question - I noticed  question from someone who bought a type 1801 which he brought with him to the U.S., and now needs to change transform to operate on 110volt AC. If that can be done, how's this? My type 1803 came with an FM-only radio. Would it be possible to swap my FM only with the AM/FM/LW radio from a type 1801? I would enjoy that. I don't expect that would be possible.
Thanks for your advice.
JackM
jhhl
Posts 9
jhhl replied on Wed, May 22 2019 2:46 AM
That spring is horrible! I thought I could just take out out, bend it  and put it back, but it's nearly impossible to replace! I ended up propping the lid up with a chopstick. If you want to be all B&O like, use a fancier, wooden chopstick instead of bamboo.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, May 22 2019 6:50 AM
Does your Beocenter have a voltage setting switch at the bottom?
Jack
Rochester, NY, USA
Posts 41
Jack replied on Wed, May 22 2019 12:03 PM
To Martin's reply - My t1803 has no voltage switch. It took me only a few minutes to realize why you ask. The 1801 operates on different voltage, which means (of course) its radio would require that voltage. It would be like putting diesel fuel in a gasoline car.
Oh well.
JackM
AdamS
Posts 373
AdamS replied on Wed, May 22 2019 1:03 PM
jhhl:
Big Smile
I have the same issue on a recently acquired Beocenter 7007. Following this sage advice, I'm going a step further and plan to contact Shun Mook, to see if they will make me a proper audiophile lid stay from mpingo wood...
Dillen
Posts 13,191
Dillen replied on Wed, May 22 2019 6:56 PM
Tighten the spring by twisting it to increase its pre-tension.
If the three claws on the inner holding plastic rail has broken, you must repair this too.
Jack
Rochester, NY, USA
Posts 41
Jack replied on Wed, May 22 2019 10:51 PM
If you mean the middle thing sticking up...guess the ending to this sentence...yes, I'll be looking thru the various brands of epoxy in the garage. There wasn't even any kind of snap, it just broke mostly off but hanging by a thread, then just dropped off. Like I didn't see that coming!
Returning the lid without the spring (fortunately) won't be a total disaster; the lid just feels heavier than before. Chopstick remedy will still apply.
Actually, I suspect this middle finger (a product of Metaphors 'R' Us) was very weak in the first place. Possibly a droopy lid signals this tab is already cracked?
I'm not sure yet whether I will attempt to fix this problem, considering that much more than the tiniest amount of epoxy might glom up the works. If I can return the parts in such a way as to have even a small amount of spring, I'll be happy (and very surprised).
And, when working with springy wire, I always wear eye protection. It can't hurt.
jhhl
Posts 9
jhhl replied on Wed, May 22 2019 11:07 PM
At one point I was thinking of machining an aluminum replacement for the broken plastic rail. But I don't have the equipment for that!
Bayoumike
Posts 7
Bayoumike replied on Wed, Oct 30 2019 1:28 AM
I am having the same problem with the plastic dust cover on my turntable.  It looks like a wire or 3 wires that create a hinge to keep it up to access the turntable.  I am looking for information on how to correct that, if I found out I will let you know.
Mike
Bayoumike
Posts 7
Bayoumike replied on Mon, May 4 2020 12:42 PM
Thanks for the response, i even thought of having someone with a 3D printer to print a new piece to correct that problem.
Bayoumike
Posts 7
Bayoumike replied on Mon, May 4 2020 12:45 PM
Thank you, I am sorry for the late response, I just found where to respond. I thought of a 3D printer to reprint a part, good idea but need someone with experience.
Mike
Phil1800
Posts 1
Phil1800 replied on Wed, Oct 7 2020 10:15 PM
Same here. Looking for a way to fix the plastic part of he hinge on my beocentre 1800 that snapped.
was also thinking a metal piece fabricated to suit and glued in place?
anything else will only break again. Tried an epoxy putty but too brittle.
if anyone has any ideas...
Page 1 of 1 (12 items) | RSS
DigiCert Secured Site Seal
