BV7, Dolby and Sky HD
This post has 1 Reply | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Dec 1 2012 10:57 AM
Hello
i have a problem that has been annoying me for a while with my setup
I have SKY HD conencted via HDMI and toshlink to optical to my BV7 on AV1
When i have the sound input set to HDMI its perfect but i dont get any dolby sound
When i have it set to Toshlink or whatever its called i get dolby on dolby programs but when i watch normal tv i get sound cut outs every few seconds, it sounds like someone is pressing mute on off quickly for half a second at a time and its annoying me
the sound works perfectly but i cannot leave it set on dolby
any thoughts?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
MartinW
Posts 389
MartinW replied on Sat, Dec 1 2012 12:58 PM
Sky can only output dolby via the digital audio output, not the hdmi - i have never understood why!
As for the sound dropping out, you may have a slightly faulty optical converter. Does your sky box have a coaxial digital output as well? You can connect that directly to the Bv7 - no adaptor required.
Page 1 of 1 (2 items) | RSS
