Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Nicely done, Steve - I like your enthusiasm 👍
Sorry for my comment..but i can not confirm that that small difference of power make that great difference.
maybe just for info..
I did take TDA chip form CAR stereo with 2x 18W sinus power and compare with BL3 power amp...125W..
and you wold be suprise how small difference in outcome is.
My vacum tube 4x EL34 power amp with maybe 60W power is waaaaaaay more powerful than any ice power amp with same rated power.
so ..rated power is gray area and in some case just number on the specifications ..
Thanks guys!
From what I can tell, the sound pressure level outputs of the Beolab 5 and 50 are very similar at maximum volume. They are unlikely to be drawing their maximum wattages from the amplifiers at this point (this would possibly only happen if the speakers were fed pink noise at max level, which would be painful to hear!
Both speakers can give in excess of 110dB in a typical room for music, which is beyond what is comfortable for the average user to listen to. hence, the slight drop in wattage is unlikely to be a problem in most cases.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I like to think it is not so much about a power rating - that is an engineering design/component element but rather the ease at which those engineering components play together?? Thus in my mind, for any measured room attenuation (or listening point), the components of each loudspeaker will behave differently and all will not be playing optimally at any one common volume?.
what website they are available?
thanks
mikeberlin:Hi, what website they are available? thanks
oli: The digital output of the Lyngdorf is going to the Beolab 5. The Lyngdorf (danish brand) provides room correction (or room/beolab5 affinity), and give the possibility to equalize digitally the signal. I only use it for room correction (equalization set to Neutral), you can set up different Focus listening positions (equivalent to the Narrow mode of the BL50) or Global (Wide mode of the BL50). The RoomPerfect feature is really a great improvement to the Beolab 5 calibration, which basically is only taking care of the bass stuff.
Hello Oli
I have a question about your setup if that's alright. I have the same setup on my mind. I now own a pair of Beolab 8000's, connected to analog out on the Lyngdorf. I would love to trade them in for a pair of Beolab 5's as well.
How have you calibrated? Beolab 5 on their own and then add roomperfect?, or just leave the Beolab 5 uncalibrated and only use roomperfect?
Cheers
Richard
