BS Moment, ML/NL Converter, Radiostations
This post has 5 Replies | 0 Followers
Wild Ruedi
Zürich Switzerland
Posts 102
Wild Ruedi Posted: Wed, May 29 2019 9:03 PM
Hello
My setup is BS Moment as NL and BS 3200 and BS 3500 as ML products. All works fine after some teething problems. I have a list of tunein radiostations on the Moment but I can not choose these direct on the ML devices.The nummeric station choice has not the desired effect. It plays any station, up and down works.        I have the suspect, that Moment does not have a nummeric list of the radiostations.
Is there a solution for this problem? Thank you !
BeoVision11, BeoVision10, BeoSound 5, BeoSound 3500, BeoLab 9, BeoLab 4, BeoLab 6000, BeoLab 8000, BeoSound 3200, Beosound Moment,NL/ML converter, delaybox, var.BeoPlay Speakers
Soren
Denmark
Posts 115
Soren replied on Wed, May 29 2019 10:14 PM
Hi
That is strange, I can choose the tunein stations directly on my ML devices.
Søren
Wild Ruedi
Zürich Switzerland
Posts 102
Wild Ruedi replied on Wed, May 29 2019 10:25 PM
Hi, thank you for the answer!
This is my experience, I wonder if there is some setting I can alter to get 123 Radistation from Moment on the ML speakers. What is your setup/ options settings?
Ruedi
Calvin
Posts 182
Calvin replied on Thu, May 30 2019 2:58 AM
I have an A9 + record player for serious music. For most other things I have several dozen cassette that are mix tapes of years and a few of genre (eg jazz if we have guests).  Thing is the Century is just a gorgeous thing to have on the wall and why would I use a speaker and my phone when I can have a stunning piece of art on the wall?
I mentioned my main annoyance against digital music in a post about a month back, the fact that all the players/software look like bad CRM database software. If there's anyone out there who's young and doesn't have a family then please steel my idea and make a music software designed visually, around the artwork of the album, maybe with the option to also show band pictures and photos of that year. If I was only 20 again I'd be a millionaire in 10 years time!
Soren
Denmark
Posts 115
Soren replied on Thu, May 30 2019 7:09 AM
My system consist of Bs Moment, Bs7000(option 0) , BV11, Bv7(opt6) BeoLab2000 (opt4) and Beolab3500(opt6) the NL/ML converter is set as V.master...what do you mean with “BS3500”? Do you have 2 ML audio systems in your setup?
Wild Ruedi
Zürich Switzerland
Posts 102
Wild Ruedi replied on Tue, Jun 25 2019 10:00 PM
Hi Soren
sorry for the late reply.
BS3500 should read BL3500. The setup is straight forward: BV11 And all the other ML products linked trough ML/NL converter. But on the ML I can not browse through the radiostation one after the other or by number. They come in different positions each time I start the system. But the are always in the same order on the BS Moment.
Difficult to explain,but nasty. Any suggestions?
Regards Ruedi
Page 1 of 1 (6 items) | RSS
