Cables neded for beomaster 2400 and beocord 1900
This post has 2 Replies | 2 Followers
travishudelson
Posts 4
travishudelson Posted: Thu, May 30 2019 5:44 PM
Hi, I'm a new member and I just inherited the above, as well as two 15 OHM Rogers monitors.  I also got a Beogram 4004 turntable, but it's not yet operable.  What cables do I need?  They appear to require 5-pin male DIN cables?
Peter
Earsdon
Posts 11,991
Peter replied on Thu, May 30 2019 6:02 PM
You need a male 5 pin din to male 5 pin din for the Beocord. The 4004 has a 7 pin din lead attached as it works by remote via the 2400. You will also need 2pin din male plugs for the speakers - which Rogers speakers? LS3/5As?
Peter
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
The extra 2 pins on the Beogram cable can be removed with a small screwdriver to allow it to fit the 5 pin Phono socket on the Beomaster.  Please feel free to get in touch via my sponsor link below if you would like any help finding the other cables to get your system working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
