Hello people!
I'm new to this forum and I hope you guys can help me out.
I just bought this beautiful player. It didn't play for some months and was transported in a safe way. After I made it ready to play (after unlocking the transport-lock) it seems it immediately stops playing as soon as I let the start-button go. Do I just need a new belt or is it some bigger issue? Anyone? Really hope someone has the solution for me, thanks in advance.
(Anwsers in Dutch are also very helpful, thanks!)
Here's a short video of the problem:
https://youtu.be/VDmFqYpnsY0
Kind regards,
Martijn Quirijns
Format: ???Duration: 25 seconds
De startknop iets langer ingedrukt houden.
Dank Blackrix, maar dit werkt helaas niet. Arm komt ook niet van z’n plek af trouwens.
- Broken servo motor belt- Bad servo motor- Carriage blocked- Electronic fault in servo motor drive circuit.
PROBLEM SOLVED! Thanks Martin, the servo belt was broken. Happy as a child!
