Hello,I just received as a gift, brand new Beoplay E8. (Last Friday 7th of June)They are really brilliant, love the sound quality, design. Unfortunately one buds (left) is quiter. Difference is noticable. I have seen plenty of solution provided on youtube by your profile, and tried each of them with no results, even the hard reset does not help.Is this something wrong with my pair?
Unfortunately I could not update in the ios app E8 firmware.
2.0 use 5.0.0, or I do something wrong, but without possibilities.
I have checked balance, was in the middle. I slighlty move into left and is fine, but should not be a solution;) maybe temporary..
Thx for your insights!
Another thing to check. Make sure that they are clean from ear wax. It can affect the sound.
Hubbe:Another thing to check. Make sure that they are clean from ear wax. It can affect the sound.
5.0.0 is the latest firmwere for E8 2.0 so far.
Thanks for all your comments. I have checked all those things.
I contacted with BO support center. After investigation root is probably in hardware issue.
Thanks!
