Beovision 10 - how to remove back panel?
This post has 3 Replies | 0 Followers
PatrickCG
Posts 8
PatrickCG Posted: Wed, Jun 19 2019 8:51 AM
Hi everybody.
The fans on my BV 10-46 are getting too noisy, and regular hoovering doesn't seem to cut it anymore. I want to remove the back panel to inspect the fans properly, to determine whether to replace them or not. How do i do that?? BTW the TV is wall mounted, right side.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, Jun 19 2019 12:53 PM
I think you disassemble these from the front.  Screen off, then you're looking at the internals...
Lee
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jun 19 2019 1:21 PM
9 LEE:
Lee
Correct.
This is what it looked like when B&O retrofitted my good old BV10 due to heat related "click" noises from the chassi.
Everything done from the front.
PatrickCG
Posts 8
PatrickCG replied on Wed, Jun 19 2019 1:39 PM
Okay, wow. Thank you.
Might just try cleaning the fans with compressed air to begin with Big Smile
Page 1 of 1 (4 items) | RSS
