BeoGram Standard Maintenance items
Chris
Oakland, CA USA
Posts 36
Chris Posted: Mon, Jun 24 2019 2:01 AM
Hello,
I bought an RX w/o a functioning needle, and I have a SMMC4 on order.
There is a "Classic Audio Repair" facility here in San Diego, California that has a lot of positive yelp reviews. I'd like to have this 80s turntable serviced/maintained.
What are the main things that need to be done on Beogram RX as the years go by.  What are the typical cleaning and adjusting and replacing the these units need?
Thank you.
DMacri
United States
Posts 881
DMacri replied on Tue, Jun 25 2019 8:42 PM
The typical items like the belts, lubrication points, and possible speed adjustments. There is also a height adjustment if the platter is not correct.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jun 25 2019 9:44 PM
What Dom said, - and the speed trimmers often need replacing by now.
I can supply correct belts for most Beogram, Beocenter and Beocord models - also the special triangular ones for the servo motor in the tangential decks.
Email or PM me.
Chris
Oakland, CA USA
Posts 36
Chris replied on Wed, Jun 26 2019 3:21 PM
So to sound intelligible when I bring my RX to the audio repair shop I can say I'm interested in having it serviced and I'd like to make sure these things are addressed;
  • belts
  • lubrication points
  • speed adjustments
  • platter height adjustment
  • speed trimmer (replace if necessary)
And I should bring in my own RX specific belts. Anything else?
DMacri
United States
Posts 881
DMacri replied on Thu, Jun 27 2019 11:08 AM
Yeah, that sounds about right to me.
Dom
Chris
Oakland, CA USA
Posts 36
Chris replied on Tue, Aug 27 2019 3:11 PM
chris_in_cal:
  • belts
  • speed adjustments
I have my replacement cartridge, and the replacement belt.  I called several repair shops and one guy agreed to work on it.
I'm going to bring it in, and if it doesn't need anything major he should be able to do these maintenance and adjustments, and I should finally have my RX playing music soon.  Thanks
Chris
Oakland, CA USA
Posts 36
Chris replied on Tue, Aug 27 2019 3:13 PM
chris_in_cal:
I realized this is vague.  What are the main (or all) places on the RX that need lubrication?
Page 1 of 1 (7 items) | RSS
