Help!!
stephanie5500
Posts 3
stephanie5500 Posted: Mon, Jun 24 2019 3:53 AM
Hi, I recently purchased this Bang and Olufsen equipment ..The lot consists of these items/ a pair of Penta tower speakers..black and silver 6603/Beo Lab 2 speaker 6883 / a Beocord 5500 Casette.Beogram 5500  record player/Beogram 5500CD player/Beomaster 5500 FM tuner / B&O Master controlpanel 5500 /Hand held B&O remote/1 Beolab 4000 speaker 6683/1 Beo Passive Link 1658/ Beo Link Converter 1613/Beo System 1 8480 couple of sensors...and a pile of 8 pin wire /7 pin wire and a huge MON cable..and lots of other stuff..I bought all of this at a local yard sale for $150.00 dollars..I don't know a lot about it or even how to connect all of it or if I even need all of it.would be happy just connecting th penta towers and the 4 major componets but I'm scratching my head here...everything fires up..remotes..cd tray..record needle moves plater spins...cassette plays..jus don't know how to connect the cables to get my sound..I think it was an excellent deal for the $$..so if anyone has any advice I would appreciate it..thanks Stephanie M.
mjmedlo
Posts 922
mjmedlo replied on Tue, Jun 25 2019 11:50 AM
Where are you locates
DMacri
United States
Posts 881
DMacri replied on Wed, Jun 26 2019 11:46 PM
That is quite a deal! You could connect the Beolab Pentas to the BM5500 using four wire speakerlink cables to light up the displays. All of the matching source components will connect with the 7 pin cables - some may be captive and others need to be connected.
The 1613 will allow you to connect the BeoSystem 5500 you the BeoSystem 1 through the Masterlink cable to the BS1 and a 7 pin audio aux cable (fully wired) to the BS5500.
The single Beolab 4000 was probably a center channel speaker and the Beolab 2 the subwoofer.
The 1658 will allow you to connect a set of passive speakers using the two pin DIN connections. You feed this amp using an 8 pin powerlink cable from the BeoSystem 1.
I’d be happy to help you hook this all together if you were somewhere in the New England area.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Couldbfishin
Houston, TX USA
Posts 16
Hi Stephanie,
This is Couldbfishin, or Gary, in Houston, TX. I have the same BeoSystem 5500 and several spares. I do minor repairs and could certainly help you with the set up. I guess the odds of you being in Houston are astronomical, so it would have to be done on line and with photos.
Do you have any manuals with this pile of equipment and wiring?
If so, look for the manual for the BeoMaster 5500. That is the receiver (preamp, amp and tuner integrated into one unit). Then look for the manual for the Master Control Panel 5500. That is the table top remote control.
If you have those, read through them and we can get started.
If everything is working, you  have the components of a fine sounding system. And, for what you paid, it is a real bargain. I bought my first system for about $250 at an estate sale 5-6 years ago and it sounds great. I have purchased additional spare components along the way, most of which need some repairs.
The cables are somewhat unique for the B&O system. Hopefully you have them all. Most will connect onto the back of the receiver/BeoMaster 5500. So, find it, set it down on a table or counter top where you can get to it. There is a black door on the back of the top of the receiver/BeoMaster 5500. It has slats in it and hinges forward. So take the back most corner and pull back on it, towards the front of the receiver. It will hinge open and you will see the places to connect wires.
Read the instruction book and let me know what questions you have. Glad to help you.
Couldbfishin/Gary in Houston TX
stephanie5500
Posts 3
Hi! Thank you for your reply to my distress call :)..that's funny I used to live in Massachusetts right up until 2015 but now I live in sunny Florida...I'm going to take you up on any information that I can get as to how this all works...this BEO LINK B&O stuff is all new to me.This stuff was all purchased at the same time from the one man that owned it,I bought it at his yard sale...he had it as a make an offer type kind of deal and had two names on a list with two offers,one at $125.00 and another for $145.00..it was the end of the day and he said $175.00 and I offered $150.00 and he accepted my offer.Sweeet...I knew it was a deal...now I asked him if this was everything and he said he believed so and he lives just down the road a bit so I may go back and see if he found anything else that he may have missed.For me it's plug two wires into the receiver and voila!..music...but this Passive Link and Link converter stuff..don't know jack about..I'm not planning on connecting it to a tv or anything else just want the speakers,cd,cassette,record player and the tuner up and running..If I just had some good pictures of these componets connected I think I could get it done....but it sounds like you can help me....and thank you.
stephanie5500
Posts 3
Hi,Stephanie here I received your message and thank you so very much for taking your time to help me with this,I will take pictures of everything I have and maybe we can go from there.I did discover the rear panel on the 5500 Tuner.Everything powers up Cassette player plays and indicators on front show that as well as the CD player and the Record Player , remotes power up with indicator displays...but when it comes to the BEO Link Converter , BEO Link Passive and the BEO LAB 4000 I get lost. I have the manual for the Record Player/CD player and the Master Control Panel 5500.I have been looking for a manual for the tuner online but have not found that yet...so if you can help I would be very grateful.
Couldbfishin
Houston, TX USA
Posts 16
By tuner I am assuming you mean the receiver, which includes the tuner, amplifier and preamplifier, all in one unit. B&O calls it the Beomaster 5500.
You should be able to download the manual from this site, but if not, let me know and I will send a copy to you.
Hope this helps.
Couldbfishin
Houston, TX
Couldbfishin
Houston, TX USA
Posts 16
Stephanie,
I just typed a second message to you and tried to attach a file to it. The file attachment didn't work and I lost the message I had typed.
So, I suggest that we try using the private message option. And from there, if you want copies of the manuals, go to email.
I will send you a private message and include my personal email address. If you feel comfortable doing it, then send your personal email address. Once I have that I can send to you lots of catalogues, manuals, advertisements, etc. for the BeoSystem 5500 and all the components.
I purchased a disk with all B&O catalogues on it. So, what I have not found online, I have on that disk. I would be glad to share that information with you, and answer any questions you have about the operation of the BeoMaster 5500 receiver/tuner/amp/preamp.
Page 1 of 1 (8 items) | RSS
