Hi Guys, I've been offered a LINN Sondek LP12 at a great price to use with my Beolab 50s and considering buying it however. The Beolab 50s and more recent speakers as i understand it is a digital speaker and if i were to connect the turntable to the speakers via the phono in (first through a phono stage) the speaker would digitise the sound which takes away the whole reason of getting a Turnable /analogue source.
Am i correct in thinking that turntables with B&O systems of recent times 17s, 18s, 20,50's & 90s is pointless if you want an analogue sound? I hope not
I've already bought Vinyls and was about to pay for the Linn sondek which is an absolutely beautiful and great sounding turntable.
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
maybe a silly question to start of with, but what do you consider to be analoge sound? And how do differentiate it from digital sound? If you would let's say record a record/vinyl 1 to 1, could you actually tell the difference?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I would say Analogue sound is sound that was recorded in analogue and reproduced in analague, This would mainly really apply to old music produced prior to the digital age. The music i want to listen to was recorded in the 50s, 60, 70s and early 80s.
I would also consider digital sound to be anything that was sampled from analogue sources like tapes. I dont think theres anything wrong with digital music. I just want to listen to Vinyl.
I confirmed with a B&O dealer that indeed the 50s (and newer speakers) will sample the analogue signal and digitise it before playing it.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
I understand what you're saying but I don't think it fully applies here as the 50's will still happily play all the faults/charm of the vinyl and if you want them to ''digitise'' it even less then you can always turn the room comp off. I have a few recordings of basically LP's and they sound very analogue/the same as analoge to me through the 50's. If analoge is the thing you want then you kind of have to say to what level as LP's are already compromised to the extent of the medium used and then also the amps, cables,cross overs and speakers them selves. In the case of your 50's you'll get the sound closest to how it is on the Record itself, just none of the in between steps will be an altering factor to any real degree. just my opinion though, try it before judging I would say
Mikipidia:I understand what you're saying but I don't think it fully applies here as the 50's will still happily play all the faults/charm of the vinyl and if you want them to ''digitise'' it even less then you can always turn the room comp off. I have a few recordings of basically LP's and they sound very analogue/the same as analoge to me through the 50's. If analoge is the thing you want then you kind of have to say to what level as LP's are already compromised to the extent of the medium used and then also the amps, cables,cross overs and speakers them selves. In the case of your 50's you'll get the sound closest to how it is on the Record itself, just none of the in between steps will be an altering factor to any real degree. just my opinion though, try it before judging I would say
I know what you are saying,- but the 50 is exclusively a digital system.
The DSP will do filter transformations you cannot possible do in an analog system, and thus the sound will never be or resemble an analog sound.
You have even (unknowingly perhaps) very accurately described that sound somewhere in one of your videos...
Note I did NOT say better or worse- just different!
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
That is not even remotely what i wrote!
Yes, the BeoLab 50s will digitise your LP12's output – but then so would a complete Linn system. In fact, Linn's latest phono stage, the Urika II, is designed to digitise the turntable's output before feeding it to their active speakers, as they believe that the best sound quality is attained by digitising the signal at the earliest possible stage. Digital speakers with DSP are simply the way high-end is going, and this will soon become the norm.
Yes the 50s are a pure digital speaker and really I do love them. I just always assumed I had an option of playing analogue especially since most dealers have turn tables in the shops. My music up until recntly was 100% digital which I love as I have hi-Rez music streaming subscription up to 24bit 192khz.
i simply wanted to play some vinyl. I tempted to move the analogue to digital conversion job to a separate device like the ps audio phono NuWave that would take the vinyl source and samples it via DSD and convert it to digital. The Ps audio also outputs pure analogue in case I want passive speakers later on for a separate listening setup.
I know this solution defeats part of the purpose of playing pure vinyl but I’d feel better as the analogue to digital converter in the 50s isnt audiophile grade in my opinion and can’t compete with standalone units. Plus I need a phono stage anyway so if the ps audio phono stage has a fantastic DAC & ADC then great.
1. I can assure you there is a conventional analog gain stage ahead of the ADC.
2. Apart from a more accurate RIAA compensation, I fail to see the benefit in not using the analog gain stage for the compensation?
Show me some facts, i.e noise figures!
3. The BL 50 could do the RIAA compensation without breaking a sweat.
That makes me feel allot better. I did suspect linn”s speakers were active with dsd but I find the products from linn esoteric in the sense they don’t explain allot on their website and they don’t have allot of dealers unlike B&O.
@ Epsilon 20
What exactly do you mean by "not audiophile grade" ?
I you want to the "purity" of vinyl you shouldn't even be considering the BL 50!
You should go for a classic analog amp and analog speakers instead.
BEOVOX141:That is not even remotely what i wrote!
Don't get me wrong the way B&O have balanced the tweeters, power application and design are top notch. BUT the DAC and ADC are quite old and outdated.
The 50s Analogue inputs which also include the power link connector uses a Texas Instruments PCM4220 Analogue to Digital converter.
The Digital to analogue converter, which I now question what the purpose is since its a digital speaker is the the Burr-Brown 1798 DAC which is a 15 year old DAC. Texas Instruments bought Burr-Brown http://www.ti.com/lit/ds/symlink/pcm1798.pdf
My portable chord Mojo DAC cost £500 has quite a significantly better DAC. My oppo 205 also has two DACs that are better than the single one in the 50s and that cost £1200.
Hmmmm......are you hunting specs - or are you listening to music?
Thats a fair question MM but I only went looking for specs to learn about the speakers that stand proudly in my living room. Normally when you buy non B&O speakers accompanied by amps its about the specs your getting for the money. The 50s are a premium speaker but they are sold on the basis of ease of use, musicality, the mechanics of the rising tweeters and design. I actually want to know whats under the hood after paying the asking price.
In my case I was going to start a new hobby collecting old jazz vinyls recorded in the 1950s and listening to them via the Beolab 50s. I could just stick to digital music which realistically is so easy to work as all the jazz albums I want are on my streaming platform in CD or Hi-rez, but want the fanfare of Vinyl.
If the speakers digitise the sound ,then buying a turntable is an expense that makes no sense unless you already own allot of vinyl.
The word "Audiophile" seems to be an emotive word for some as it brings up thoughts of non B&O fans lambasting our tastes in loud speakers. Personally I I would never get a set of speakers that required a rack with amps, pre-amps, power conditioners, mono amp for each left/right speaker as honestly it would look a mess and want speakers that fit into my life not the other way round. And yes you would be continuously trying to balance the Hifi racks if I chose different components from different makers. I'm sure if you got a pro to pick the components that system would rival the 50s in sound but not overall package.
I agree that CDs, SACDs and certainly uncompressed digital sound is superior to Vinyl. With Vinyl its a lottery of what you will get in terms of sound quality especially when buying older records.
If I bought a cheaper turntable, I probably wouldn't care so much abut the digitisation of the analogue signal but the linns cost an arm and a leg I obviously want to get the best out of it.
Lets not forget all the hi-rez streaming applications like Deezer Hi-fi, Tidal and Qobuz will take analogue sources for the older music and convert them to digital. It just wanted a chance to experience analogue sound , whether for the good or bad, at times when I want to chill out and listen to music in a ceremonial fashion
Mikipidia: I still say to just get a turntable you like and try it out, you need to have it anyway, and maybe it surprises you and you’ll like it as is.
I’d second that - give it a try!
P.S. ever considered a Beogram turntable, one with the tangential tracking - maybe a Beogram 4000?
I have a turntable plugged into my Beolab 90s via a phono preamp and preamplifier (not a cheap one, either!). I also worried that it was pointless due to the digitisation of the signal.
I needn't have worried - it sounds stunning and blows all the other sources into the weeds!
MM - I did originally try and get a Beogram Turntable for 3 months looking on ebay, speaking to dealers and private sellers but i there were so many models in various conditions so couldnt decide on which one to get. Plus there was a concern that i would struggle (have to pay an arm and a leg) to get replacement styluses and cartridges for these vintage and/older models. I then went the opposite direction to look at Pro-ject and Rega turntables and they were perfectly good but didnt like any other designs as i wanted something with a wood finish. I then stumbled accross a LINN dealer selling a mid- range Sondek L12 (they have a low, middle & high end player) at half the usual price. So essentially the LINN ticked all the boxes.
MIKIPEDIA - I really like the design and Ultimately I really want to listen to Jazz from the 40, 50's and 60s and allot of the artists from this time are getting their music re-pressed in new Vinyl from the original master tapes by companies like Mobile Fidelity, Blue note records and Music Matters Jazz. They wont be getting a release digitally as far as im aware and they will sound superior to the original Vinly pressings. So in short ill be going for it. And as Politician pointed out, LINNS top of the range phono stage the URIKA II digitizes the signal before sending this to its amps and speakers just shows that it can work if you pick the right components. Although i say this without having listened to a digitized analogue Vinly
I think that B&O should give form of "official advice" of what devices work best with their speaker - things like streamers, Turntables, Phono stages etc. I know they do this in the IDEA CATALOGUE that i've seen online but they didnt include turntables.
I have two options for the phono stage after some modest research time.
Option 1- A Schiit Audio Mani phono stage which costs £149 & has stella reviews or option 2 the PS audio Nuwave phone stage (£1k). I'm learning towards the cheaper phono phono stage while i learn what works best with the speakers.
AdamS - What phono stage and preamplifier are you using?
Epsilon20:It just wanted a chance to experience analogue sound
Then as said several times, the 50 is NOT your choice! And its NOT about how or where you do digital conversion or what nots!
The 50 processes the signal in ways you cannot do in an analog system, and thus the sound will NEVER have the properties of analog sound!
Its a bit like asking for the CRT TV experience on an OLED screen, No matter how gorgeous the OLED technology is,- it will never happen!
So in this case you need to get a full analog setup if you truly appreciate the properties of analog sound.
DMacri:Just one more thought - since each Beolab 50 is basically a mono speaker, does it need the power of a top of the line recent stereo ADC? Would an older, known and reliable chip be a satisfactory choice? I just wouldn’t automatically discount it as a viable solution is all.
You have to elaborate a bit here, how did mono sneak into that question?
Where in the signal chain are you considering putting in an ADC?
BEOVOX141: Epsilon20:It just wanted a chance to experience analogue sound Then as said several times, the 50 is NOT your choice! And its NOT about how or where you do digital conversion or what nots! The 50 processes the signal in ways you cannot do in an analog system, and thus the sound will NEVER have the properties of analog sound! Its a bit like asking for the CRT TV experience on an OLED screen, No matter how gorgeous the OLED technology is,- it will never happen! So in this case you need to get a full analog setup if you truly appreciate the properties of analog sound.
Your right BEOVOX, Worst case i can just buy some relatively affordable passive bookshelf speakers, an amp to power them and i'm golden. Obviosuly this would would mean i have another audio setup in another room but that would be a pure audio chain.
Epsilon20: AdamS - What phono stage and preamplifier are you using?
Anatek MC1 phono preamp and Yamaha CX-10000 preamplifier.
BEOVOX141:You have to elaborate a bit here, how did mono sneak into that question? Where in the signal chain are you considering putting in an ADC?
Jeff
Jeff:Jeff I'm afraid I'm recovering from the BeoVirus.
@ DMacri
DMacri:and there would be no influence from another signal to contend with - no cross-talk from the alternate signal channel
120dB is considered threshold of pain for sound.....
Mikipidia:the slave speaker is basically passive
Where did you get that idea from Please elaborate
I follow the conversation Dom, I just am amazed at the lengths some people go to, not you, to argue about how many digital angels can dance on the head of a pin.
Epsilon20:Am i correct in thinking that turntables with B&O systems of recent times 17s, 18s, 20,50's & 90s is pointless if you want an analogue sound?
So I guess in the end the answer is "no, it is not pointless". You can route the analog signal from your LINN/preamp combination to the Beolabs, or use an outboard ADC, if you think it may provide superior performance, and route the digital signal to them. Either way, the original analog signal will be digitized, but that doesn't mean the signal will be altered so significantly in the process to ruin the experience.
BEOVOX141:Where did you get that idea from Please elaborate
In producing a reissue album, the original masters are digitalized, processed, etc. Finally a record is pressed.
But what is the point of this discussion (in this hypothesis) if he wants to experience vinyl if even the origin of the vinyl was digitalized!
Mikipidia:The 50’s have one dsp(chip) for both speakers in the master speaker
Based on the information in the technical sound guide, I find this very hard to believe.
Do you have anything that could support the claim?
Carolpa: Epsilon20:Am i correct in thinking that turntables with B&O systems of recent times 17s, 18s, 20,50's & 90s is pointless if you want an analogue sound?And now the game changer, just a hypothesis: Epsilon20 wants to listen to jazz of the 50 of the last century. So he is buying new reissued albums. In producing a reissue album, the original masters are digitalized, processed, etc. Finally a record is pressed. But what is the point of this discussion (in this hypothesis) if he wants to experience vinyl if even the origin of the vinyl was digitalized!
Amen, brother!!! If I remember correctly, the original demos of BeoLab 90 were done with Spotify tracks, and BeoLab 5 had their own demo CDs. I gave away many hundred records mainly because I was a partyophile vs an audiophile, and the warmth of my records (even with a nice system and many special masters) probably came from spilled drinks and cigarette smoke. Digital is good enough for me, and I only wish I could have a set of top BLs to prove it.
