Beolab 50 and Turntables - Is the sound digitised
This post has 91 Replies | 0 Followers
Puncher
Durham
Posts 11,729
Puncher replied on Wed, Jul 3 2019 3:08 PM
Geoff Martin:
One last thing...
To answer the question posed in the topic of this thread:
yes.
Smile
Cheers
-geoff
I would say Yes, if he means an all analogue signal path, and No if he means "sounds non-analogue" (whatever that is)
Ban boring signatures!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Jul 3 2019 4:12 PM
Puncher:
Yes but this is authentic analogue crosstalk!Laughing
Big Smile
And analog surface noise!
Jeff
Geoff Martin
Struer, Denmark
Posts 672
deleted
Mikipidia
Posts 2,169
Hi Geoff,
Thank you! DM'ed you again, but just in case, my public email address is mikipedi4@gmail.com Big Smile
Thanks again in advance.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia
Posts 2,169
Hi geoff,
I don’t know where my messages are going, sent another 3 now, 2 to this thread(with questions) and sent you another DM. Just in case, iam now trying via the app, one of my email adresses is mikipedi4@gmail.com Big Smile
Thank you in advance.
Michael
Razlaw
Posts 4,345
Razlaw replied on Wed, Jul 3 2019 8:49 PM
I am waiting for my 50s to be delivered. Thank you very much Geoff for all of the information you provided here. Makes me even more eager for them to arrive. Thanks again!
Mikipidia
Posts 2,169
PM'ed you once again Geoff, Thanks in advance!
michael
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Jul 3 2019 10:04 PM
Er der ikke en bog 'Røv kysse dansk For begyndere?'
Jeff
Millemissen
Flensborg, Denmark
Posts 14,680
Jeff:
Nice try 😂
Millemissen
Flensborg, Denmark
Posts 14,680
Geoff Martin:
apologies for using this forum to send a PM... but...
@mikipidia: I'm trying to respond to your message via an internal email via BeoWorld, but you seem to have that feature disabled. Send me a PM when you have enabled it and I'll answer you.
cheers
-geoff
Hej Geoff,
should that fail, here is his email: mikipedi4@gmail.com
(One that he himself has published here in his Beotalk thread).
Hilsen
Mikipidia
Posts 2,169
Mikipidia replied on Wed, Jul 3 2019 10:45 PM
Hi Geoff
What Millemissen said is correct, and thanks for that MM. I posted several times on here and pm’ed you(geoff) twice I think(within a few mins of your post) and tried to post on the thread but nothing seems to pop up. I don’t know what’s going on..Huh?
So yes, one of my email adresses is: mikipedi4@gmail.com
Thank you both!
Michael
Geoff Martin
Struer, Denmark
Posts 672
Mikipidia:
Hi Geoff,
Thanks for dropping some knowledge on us, I stand corrected in my assumption.
May I ask though, why does the product page on the website list lab 50's as having 1 dsp and the lab 90's as having two of them? And what's the difference there?
Also in both whitepapers the dsp' are listed as the same in both speakers at the same frequency but when you look up the part nr the ones in the 90's run at 450Mhz vs 400Mhz in the 50's, is this a copy paste thing or are they the same?
Thank you in advance!
Michael/Mikipedia
The reason the 50 has 1 DSP and the 90 has 2 is firstly due to the fact that the 90 has more than twice the number of loudspeaker drivers and therefore needs to do more processing.
In addition to this, in the 90, part of the audio processing is actually running 2 times in parallel - sometimes... This is so that, when you switch from one directivity to another (say, narrow to wide), for a short time, both directivities are being simultaneously calculated in the DSP and the loudspeakers crossfade smoothly from one to another. In comparison, in the 50, when you change between directivities, the loudspeakers fade out, load the new coefficients, and fade back in - so there's a "break" in the sound.
Regarding the differences in clock speeds, the answer is "I don't know". It's probably due to system optimisation by the SW & HW teams. If there is an error anywhere, it's probably in the Technical Sound Guide. (that's the problem with being the writer and the editor... it's harder to see your own mistakes than it is to admit you even make them in the first place...) I'll check on this and, if it's an error, fix it for the next release of the document.
Cheers
-geoff
Page 3 of 3 (92 items) < Previous 1 2 3 | RSS
