Mates,
I currently have a BV4-65 in the main room with a BV9 in my bedroom.
I also have Beolab3500, beolink active, (bv10 coming soon) on the ML network.
I do have a masterlink gateway connected as well.
My questions are:
what benefit do I get in putting the BV9 on the ML network?
with a new(ish) non 3D bsys 3 do I still have to use analog in to distribute sound?
can the BSYS3 distribute video signal?
I think the benefit of connecting the BV9 is if you have a soundsystem aswell so you can listen to music on the BV9. And if you start watching a movie on one tv, e.g. livingroo, you can link the movie to the other tv and end it in e.g. bedroom and finish it there.
I think the signals still is analogue. And yu have to distribute the coax signal aswell.
mjmedlo: with a new(ish) non 3D bsys 3 do I still have to use analog in to distribute sound? can the BSYS3 distribute video signal?
