Hello,
Since a few days, my Beo6 shows a strange behaviour.
If I touch an icon on the screen, the highlited icon is an adjacent one, as if the screen calibration was wrong.
I did not make any change in the configuration and the default mostly happens on the upper rows of the Beo6.
Is there a way to re-calibrate the touch screen, or could it be a hardware failure?
Kind regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Hello!
No one can help?
My dealer is of no help and my Beo6 is nearly unusable.
You are right,
My Beo6's battery went completely out of power and the problem appeared when I switched it on after recharge.
It did not came to normal after several power off/on cyclings.
Is it a common issue with Beo6?
Have you cleaned the screen?
I have seen this before when there is dirt on the screen
Thanks,
The screen is tidy, I tried several uploads of my current configuration, built a new one from scratch, nothing works.
Is there a hard reset or an in-built screen calibration tool in the device?
