BeoTalk 1200
Sbfbdo
Posts 7
Sbfbdo Posted: Mon, Dec 3 2012 7:18 PM
Hey Guys i need some help...
I have got the device up and running and just need the cable which goes from the phone line to the input on the black 3way adapter.
Do i need an rj11 to BT line, 2 pin or 4 pin cable?
Simon
Chris Harrison
Peak District
Posts 381
Your local B&O shop will be able to order your the connector. Basically the Power adapter has a telephone plug and so does the telephone to block adapter - they all plug in the black 3 way connector and then your Beotalk / Beocom plugs into the block too.
Hope this makes sense. All parts available at the B&O shop. They are the same parts as for the Beocom 4.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
All you need is a POTS RJ11 4 pin "crossover" line (YGRB -> BRGY) for the wall->tridapter.
The tridapter->BT should be a straight (YGRB -> YGRB).
Available anywhere for a nickel.
P.S. Do not get hung up (Laughing) with the colors -it is the pattern that is important!
  • One B&o bottle opener
  • One fancy gun
Page 1 of 1 (3 items) | RSS
