A friend of mine has 4 Beolab 8000 speakers. But recently his Beovision TV broke, now he bought a Samsung TV but he wants to connect his speakers again. Is there any way possible with some kind of adapter for the B&O 8 pin connectors?
I found these, but the thing is, he has 5 speakers: https://soundsheavenly.com/bang-olufsen/11-312-7-pin-aux-splitter-dual-aux-tape-input-sockets.html#/20-length-02m
https://soundsheavenly.com/line-in-connection/33-power-amplifier-to-beolab-line-in-attenuated-convertor-kit.html
Please help!
Please note that the Beolab Speakers need a controlled preamp output from his source (TV in this case). Not a set output. (Most audio jacks on TVs have set outputs, except for headphone jacks) That allows for volume control from the source.
See the attached link https://archivedforum2.beoworld.org/forums/t/28454.aspx
Contact Steve at SoundsHeavenly. He will be able to provide a list of suitable options. If you want true surround sound though (like would have been in place with the old BV) then the best thing would be to add a A/V receiver that has surround sound pre-outs and connect the 8000's to these pre-outs.
If he can afford it, an Almando 5.1 channel AV system, has Hdmi Arc to allow TV remote to adjust volume. Plus its super small so can be hidden away
I recommend these to clients and the ones that purchase, love them!
