Beoplay H9 - can't use mic and headphones at the same time
This post has 8 Replies | 3 Followers
kelsett
Posts 5
kelsett Posted: Mon, Jul 22 2019 10:33 PM
I'm currently using my Beoplay H9 3rd gen on my computer (Windows 10). I'd like to use it as a headset for playing video games with friends, however whenever I use the microphone the sound switches to much lower quality speakers, identified as a "Beoplay H9 Hands-free" device in my sound manager, as opposed to the regular "Beoplay H9 Stereo" which plays everything fine. The issue is fairly simple to reproduce : try listening to some music and calling someone on Skype at the same time, the music will stop and you won't be able to play it until the call is finished.
It seems odd that one wouldn't be able to use the microphone and the HQ headphone functions at the same time especially for such a high end product so I'm wondering, am I doing something wrong ? For the moment the only solution I have is to disable the "Beoplay H9 Hands-free" and use a separate microphone.
davidr
Montréal
Posts 172
davidr replied on Tue, Jul 23 2019 9:12 PM
Maybe something to do with how the PC pairs its BT.
Pairing my H8 to my phone no problem, I can receive a call, answer it, and have two way voice. Once done, it goes right back to music. Never tried pairing it to a computer.
kelsett
Posts 5
Thank you for your reply. It does work both ways, but what I mean is it sounds like it physically switches to a lower quality speaker when using the microphone, and it won't switch back to decent sound quality again as long as the microphone is active. I've attached a screenshot of my sound manager.
iLard
Posts 1
iLard replied on Sun, Feb 16 2020 11:32 AM
This is because using the mic turns the headset into phone mode, and it's designed to allow you to hear your own voice so it's a more normal telephone experience.  This makes it less suitable as a gaming headset.  I do wonder what happens if you use a wired connection instead of BT, but really I think you have the wrong product.
kelsett
Posts 5
kelsett replied on Sun, Feb 16 2020 12:56 PM
Thank you for your reply. Yea I figured ... but was hoping maybe someone knew some trick to make it work.
protonoto
Posts 3
protonoto replied on Tue, Apr 14 2020 10:45 AM
Did you ever resolve this issue?
kelsett
Posts 5
kelsett replied on Thu, Apr 16 2020 8:48 AM
Sadly not, I have to use a separate microphone on my computer... Such a shame
ballsmaster
Posts 1
Would this solve your problem?
https://www.bang-olufsen.com/en/accessories/ios-cable?variant=headphone-cable-3-buttons-black
It says iOS but I think it should work on a pc as well. Does anyone have experience with that headphone cable?
leosgonewild
Helsinki, Finland
Posts 2,373
Get a cable with a microphone. If you are gaming you dint want delay in sound Wink
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
