How do you listen to internetradio on your Beovision Horizon/14/Avant NG/Eclipse?
This post has 7 Replies | 0 Followers
Master123456789
Posts 237
Master123456789 Posted: Thu, Jul 25 2019 5:11 PM
The only thing I can find is the Tunein app via Google Play-store. Is that the only way?
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Thu, Jul 25 2019 5:22 PM
Yes, app or use a netradio / tunein source from multiroom player such as the beoplay A9/A6/M5/M3, beosound 1/3/35/moment or boxed units as core. You can then join the Horizon to the tunein or lent the tunin source without activating the other sound system
Millemissen
Flensborg, Denmark
Posts 14,680
Master123456789:
....and what is wrong with that?
It is an app like other (Android) apps.
You will need to make an account on the TuneIN website - choose the free one, it is ok.
With these credentials you can log in in the TuneIn app on your tv.
You create your favourites on the TuneIn website respectively in the mobile app - these will then appear in the app on the tv......once you are logged in there.
P.S. From the user manual:
Music and video services
Access services such as Spotify, Deezer and TuneIn, if you have the required subscriptions, and search through and stream for every occasion’
Master123456789
Posts 237
Yes, that is good if I could find the login. πŸ˜‰Here is my picture from the TuneIn at my bv horizon
These are the possibilities. Does your picture also look that way? Where do you login? 😊😊
Master123456789
Posts 237
No one who can help me with login with the account?
andybandy
Posts 164
andybandy replied on Sat, Jul 27 2019 9:30 AM
Its not possible to login in tou your account.
I recommend everyone that have a horizon/BV14/avant andriod version to send in request to tunein.
To push the developer of the app to fix this. Its the only thing that missing in that TV.
andybandy
Posts 164
Master123456789
Posts 237
Do you agree millemissen? It is not possible?
Page 1 of 1 (8 items) | RSS
