Beolab 3500 and 2000 as airplay speakers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Fri, Aug 9 2019 10:40 AM
A thought occured to me that if the autosesnse circuits used in the Beolab Active speakers could somehow replace the ML circuits in a Beolab 3500 and 2000. An airplay device could then be attached and the speakers used as an airplay device or soundbar?
I suspect there are complex technical reasons why this isn't possible but thought I would throw it out there
madskp
Denmark
Posts 321
madskp replied on Fri, Aug 9 2019 3:41 PM
Should be possible with this product https://almando.com/index.php/b-o/beolab-3500-tv-soundbar/almando-masterplay.html
Haven’t tried it myself, but i am using the power link switch from this company for my setup and am very satisfied with that product
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Andrew,
Masterlink relies on a data "handshake" between the system and speaker, so there isn't a simple "sensing" process with the Beolab 2000 and 3500 as would be the case with a Powerlink speaker.
However, if you don't mind using a B&O remote to activate the speakers before first use, then you can easily plug a streaming music player with a headphone socket (eg. Airport Express, Chromecast Audio, etc) into these speakers via these cables:-
Beolab 2000 cable: https://soundsheavenly.com/airport-express/164-2495-ipodtvairport-express-to-beolab-2000.html#/2-length-1m
Beolab 3500 cable: https://soundsheavenly.com/airport-express/155-2345-ipodtvairport-express-to-beolab-3500-mk2-cable.html#/2-length-1m/63-beolab_3500_version-mark_2
Hope this helps.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Aug 14 2019 11:16 AM
Thanks Steve - I found that I had a spare beolink converter so I hooked that up to the Beolab 2500 and connected it to a Toslink to Analogues converter via the AUX IN - now I am able to control my TV with a Beo4 via a lintronic box and have the sound come out of the Beolab 2000 placed behind it - it works superbly and the sound quality if much better than the Panasonic Sound bar I purchased!. It will do anyway until I get a proper B&O TV again. The problem I've found with Panasonic Sound Bar was that to turning the volume up and down takes forever whereas the B&O TV's and stereo's are just that much faster and better sound quality in the first place. Anyway, it's one way of giving these old products a second lease of life - I would have used the 3500 underneath the TV as that would look better but it was too wide for the cabinet.
Page 1 of 1 (4 items) | RSS
