stand control button pushes
This post has 1 Reply | 2 Followers
davethom
Posts 1
davethom Posted: Tue, Dec 4 2012 10:55 PM
Hi can anyone help?
I am looking to send stand control movement to a beovision 7-55 through the masterlink gateway but so far all i've managed to do is very small steps....on the standard remote my client has all she needs to do is select stand from the list menu and use the curser control to move left/right/up and down however these 'button' pushes on the masterlink gateway don't seem to work? does anyone know the correct configuration to have a continue to move until a button release command is sent?
Would much appreciate any help anyone can give on this....really confused now!
Seanie_230
UK
Posts 2,278
Dont know if this helps but when i am in front of my TV i can use Stand 1,2,3,4,5,6,7,8 & 9
5 is about middle
good luck with your tests
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (2 items) | RSS
